Question about Mastercool 99772-A, Complete Digital Manifold Kit w/3-72" hoses
How to reset a mastercool digital manifold gauge when hp stay 66 bar any hose conected
How to debug to reset to return it to o
Ok i jus buy a ac chek presure manifold, i wanna recharge mi ac carcompresor but the manual donat said how conect tha house in the r134a can, just said how to chek the presur,, can some one help me with...
To connect the hose to the can, it should have a locking ring with a valve. Some connectors screw on clockwise, and others snap on and clamp downward with a locking lever. To open the can, just turn the T valve down clockwise. To release the freon into the hose, turn the valve to the left. Never remove can from the valve assembly, until the can is empty. If you have no clamp and valve for the freon, just a hose, you can buy one at your local auto parts store
Jul 30, 2011 | Mountain R134A Brass Manifold Gauge Set...
Tip
How to solve safari slow script error
This error prompt is easily remedied, however, you'll need to access the Safari Debug Menu to do so. If the Debug Menu is activated, click on it in the Menu Bar and uncheck "enable runaway JavaScript timer. That ought to solve this problem.
If the Debug menu is not activated, follow these instructions:
Quit Safari
Open Terminal.app in your Utilities folder,
When the Terminal window opens, copy & paste the following command into the window:
defaults write com.apple.Safari IncludeDebugMenu 1
Click on the return key, you may be prompted for an admin password. If so, enter it.
Press "return".
When you see your Mac's name, it's done,
Quit Terminal
Restart Safari and go to the Debug Menu, following the suggestion above.
on Mar 17, 2010 | Apple safari
Need to remove the water pump
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
WATER PUMP REMOVAL
  1. REMOVE RH ENGINE UNDER COVER
  2. DRAIN ENGINE COOLANT
  3. REMOVE GENERATOR (See page CH-8)
91329747
  1. REMOVE INTAKE MANIFOLD STAY
  1. REMOVE WATER INLET PIPE
(a) Disconnect the following hoses: 91329748
(1) Water inlet hose (2) Heater inlet hose (3) Water bypass hose 91329749
(b) Remove the bolt, water inlet pipe and 0-ring.
  1. REMOVE OIL DIPSTICK GUIDE AND GENERATOR ADJUSTING BAR
(a) Remove the oil dipstick. (b) Remove the mounting bolt of the dipstick guide clamp and generator adjusting bar. 91329750
(c) Pull out the dipstick guide. Plug the guide installation hole of the oil pump. (d) Remove the 0-ring from the dipstick guide. 91329751
  1. REMOVE WATER PUMP
    • Remove the bolt, 2 nuts and water pump.
Jan 02, 2011 | 1992 Toyota Tercel
How do i hook my manifold gauges to my residental condensing unit to check pressures
The AC manifold gauges set have the three chambers: the low pressure chamber (left side), utility chamber (middle), and the high pressure chamber (right side).
When technicians connect the HVAC manifold gauge to the air conditioner units, he connects the low pressure side of air conditioner unit to low pressure gauge side.
If he wants to read the pressure in discharge line he connects the high pressure gauge hose to the air conditioner high pressure side.
The utility port (the middle chamber) is a place you connect the hose to vacuum pump, recovery units or add or remove refrigerant from AC units.
Air conditioning gauges is used to measure air conditioner units pressure within closed-system to evaluate or troubleshoot the AC units. Gauges manifold set is the most frequently used item when it comes to refrigerant or pressure.
Air conditioning gauge set allows the HVAC technician to check AC units operating pressures, transfer AC refrigerant, pressure test system, purge the system with nitrogen, and perform other necessary tasks.
The gauges manifold set includes the hoses, the manifold, the valves, the compound gauge (low pressure gauges) and high pressure gauge.
Jul 24, 2010 | Heating & Cooling
Mobile Mastercool MMB10B set up help needed
It has a float valve so when you connect it to the hose it stays full. The unit holds about 5 gallons but in a hot dry climate that can vanish in an hour or two. A lot of people use a 5 gallon bucket on top of the unit connected to the water inlet with a short hose. It will still need to be filled up but you can run it longer between fills and no hose to trip over.
Jul 16, 2010 | Mastercool Portable Air Conditioner
2000 grand cherokee V-8 stalls out
Start the engine cold and as it warms up, pull the vacuum hose off the EGR valve and see if it keeps running. If it does, replace the EGR valve. The reason the lights are all coming on and the gauges go to zero is because the engine dies and when it starts they return to normal. The EGR valve can stay stuck closed from carbon deposits which is fine for the warm up mode but it needs to open when the engine is warm or it will choke it out. This is not unusual and you will need to replace it. Look on the internet for your make and model an image of your EGR valve it will be easier than explaining it to you. They are in most cases on or connected to the intake manifold or intake plenum.*** Please rate me on this answer.***
Jun 06, 2010 | 2000 Jeep Grand Cherokee
Wifi button won't work When I depress the wifi button it stays orange instead of turning blue.
Look by the clock.. on the start bar for a icon to conect
open it and makesure its on,, and then conect to you WIFI, try reseting your wifi router, try reseting your internet box
If you already know how to do all that with no luck,
check the drivers for the wifi card
Its ether not conected to a network, lost driver, wrong network setings or bad wifi card.
May 16, 2010 | HP Compaq nc6220 Notebook
Where can i get replacemnt o-rings for hoses
there are many dealers for these products,ask them for the replacement.
Jun 29, 2009 | Mastercool 89660 R134a Manifold Gauge Set...
Gauge manifold readout interpretation
First of what is the problem taht you are having? To properly diagnose a air conditionign system yoiu have to look at more then just the refrigerant pressures. There is airflow and also duct design and a whole list of other variables. If you haven't done it then my suggestion is to checkout the local colleges in your are and see if they have ight classes to attend to learn more. I had to go to school for 2 years to get my degree and am still learning every day that I am working. thats been 20 years now. Good luck.
Jan 02, 2009 | Mastercool Measuring Tools & Sensors
Vacuum gauge installation
look for a vacume tree at rear of intake manifold and y in.You want manifold vacume not venture vacume so stay away from throttle body.
Nov 24, 2008 | 1999 Chevrolet Suburban
Mastercool 99772-A, Complete Digital Manifold Kit w/3-72" hoses Logo
470 people viewed this question
Top Mastercool Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Mastercool Measuring Tool and Sensor Expert? Answer questions, earn points and help others
