Question about Samsung Washing Machines
My Samsung washing machine B1245a, is leaking from the bottom, though it is working good, what should i do ?
Machine is leaking from the bottom, though it is working good, moreover while, spin and rinse it vibrates
    Genius:
  • Samsung Master
  • 1,585 Answers
Check pump
Posted on Apr 18, 2015
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Water coming out from bottom of washer
Lift and support your washer. Check all hose connection on the bottom. If all hoses are good you may have a leaking water pump.
Sep 10, 2014 | Samsung SW62ASP Top Load Washer
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Sometimes the next morning after I have washed a load of clothes that evening, even though at night there is no water in the bottom of the machine, the next morning there is a small puddle in the bottom. ...
i think the drainage of your washing machine, is not functioning well,or it has a leak, that's why some water remain in the bottom of your machine..
check this one..
http://www.washingmachineadvisor.com/
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My machine has a small water leak though the door during washing
Replace the gasket. Or make sure that the gasket is sealed properly
Feb 10, 2009 | LG WM-2032H Front Load Washer
Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Washing machine is leaking from the bottom
try looking at the tubes where the filter is. remove the front cover at the bottom and check the filter. worth a shot
Nov 13, 2007 | Samsung WF203ANW Front Load Washer
Water leaking from washer
you most likely have a pump leaking post your email so i can send you the manual
Nov 03, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
49 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
