Question about Quasar Televison & Video
Need the 3 digit code
Bus VhV VhsVhs940
  • 937 Answers
I can only suggest that you search online under the make and model number. Anyway, what's the 3digit code for? I think that you need to give a few more details.
Posted on Jul 02, 2015
Why does a bus er code comes up on my 2007 Harley Davidson ultra glide
"BUS Er" indicates Serial data bus shorted low/open/high. It is number 1 priority DTC fix
If speedometer reads "BUS Er" with the ignition key turned ON with the run/stop switch at RUN with the engine off, check the data bus for an open or short to ground between the data link connector [91A] terminal 3 and ICM connector [10B] terminal 12 on carbureted models, AND on EFI MODELS, ECM connector [78B] terminal 5 , TSSM connector [30B] terminal 3, speedometer connector [39B] terminal 2 or if a tachometer is installed, tachometer connector [108B] terminal 2.
Also check for an open diagnostic test terminal between the data link connector [91A] terminal 3 and the TSM/TSSM connector [30B] terminal 3. With the ignition key turned ON, serial data bus voltage should be typically 0.6-0.8 volts. The range of acceptable voltage is 0-7.0 volts.
Wiggle the instrument and/or vehicle harness to identify possible intermittent problems.
Jul 11, 2014 | 2006 Harley Davidson FLHTI Electra Glide...
Code u1000 code p0105 u1152
Codes U1000 & U1152 are related to the digital data bus communications, U1152 is specific for the HVAC control unit data bus. troubleshooting this will require a Tech II scan tool.
P0105 is related to the MAP sensor circuit.
Apr 27, 2014 | 2002 GMC Envoy
Dell m90 beeping codes
Dell BIOS Beep Codes: Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Mar 03, 2013 | Dell Computers & Internet
Trouble Codes
1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
Fault location = Malfunction Indicator Lamp (MIL) - request signal active
Probable cause = Trouble code(s) stored in other system(s)
3. VW VAG type 5 digit fault code 01039:
Fault location = Coolant Temperature Sensor (G2)
Probable cause = Open or Short to Plus, Short to Ground - Intermittent
4. VW VAG type 5 digit fault code 01304:
Fault location = Radio
Probable cause = No Communication
5. EOBD type P0761 fault code:
Fault location = Shift Solenoid C
Probable cause = Performance or Stuck OFF
Feb 03, 2010 | 2002 Audi A4
I need drivers for laptop sps 1210
all Drivers for your computer can be found here
u most look what u already got what not
If it helped rate fixya
Aug 03, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Televison & Video Logo
167 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
