Question about Ovens
The oven door is squeaky. Is there a heat resistant lubricant I can use?
2 Suggested Answers
  • 18 Answers
SOURCE: type of adhesive for an oven door that is heat
You need a heat resistant adhesive specifically intended for ovens.
Posted on Jul 24, 2010
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
Oven won't unlock
You sound like you have a temp sensor error. Without knowing your exact model I'd say that you can open the door with a coat hangar , the latch is at the top in the center it is locked to the right (facing the front of the door), and it is spring loaded
Remove the temp sensor and take a ohm reading.
Appliance Tip of the Day: Oven Temperature Sensors Demystified grasshopper%202.gif Everyone knows what thermostats do: turn something on and off based on temperature. If your range has an electronic range control (ERC) board with the digital LED display, it doesn't have a thermostat. You know what I'm talking about, most ERCs look something like this.
tn_tempsensors.jpgRanges with ERCs use a sensor to "feel" the temperature in the oven cavity and sends that information to the ERC. The ERC then makes decisions about about heating the oven and controls the burner (in gas ovens) or heating elements (in electric ovens). Typical styles of range temperature sensors are shown
Inevitably, your range will one day start acting goofy and you'll need to check the oven sensor to see if it's causing a problem. On most ranges, a big clue that the sensor is the problem is if you're getting an F1 error code in your ERC display. So how do you check the sensor? Keep reading.
Oven sensors sense the temperature is the oven cavity by increasing their internal resistance, measured in ohms as the oven's temperature increases. This change in ohm resistance tells the ERC the oven cavity temperature and it turns the heating elements or burner on and off, as needed. Now, hang with me, grasshopper, 'cuz we're getting to the good part.
At room temperature, 70°F, the resistance of the most common sensors used today is 1000-1100 ohms. What this means is that if you pull those sensor wires to measure the sensor's resistance and it reads slap-a$$ open, why, it don't take a rocket scientist like myself to figger out that you got yourself a bad sensor! Wasn't that easy?
Just for grins, I've included the table below to show you the sensor resistance reading at various temperatures. Viva la resistance!
Oven Sensor Resistances Temperature (°F) Resistance (ohms) 100 1143 200 1350 300 1553 350 1654 400 1753 500 1949
Dec 12, 2007 | Ovens
Noisy fan
Only graphite lubricants are heat resistant. The fan could be worn out, bearings just well done. (oven humor).
Nov 28, 2013 | Ovens
Heat cuts off on oven after being on for about 30 minutes. Code F2 appears.
Hi, F2 code means that the Oven temperature is too high.....
Solution:
  • Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
  • For SELF CLEAN models: check door lock operation.
  • Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember:
  • Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Oct 14, 2010 | Whirlpool RBS275PD Electric Single Oven
F2 error and door locked display while self cleaning and fan will not turn off for 4 hours after using oven
F2 during the cleaning cycle will occur when the oven control senses an oven temperature above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
**((The fans will continue to run if the control has been damaged, due to the high heat))
Sep 09, 2009 | GE Profile JTP56 Electric Double Oven
Self Cleaning over-heats, flashes F2 code and beeps until I flip the breaker. This is a wall unit.
Hi, Your Control senses oven temperature above 915F-930F
Jun 22, 2009 | GE Ovens
E1 f2 error
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem.
· Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
Good Luck
Sep 05, 2008 | GE Profile JT912 Electric Single Oven
The inner glass of my sons built in oven door has fallen out can you please advise how we can fix it thank you it is neff b1420
The inner glass panels are bonded to the frame with a heat proof adhesive.
The chances are you will have to get a complete new door assembly.
Jul 22, 2008 | Neff B1421 Electric Single Oven
Neff u1721 fan door problem
yes it is a heat resistant adhesive and ive never had any success in regluing them
Nov 06, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
