Question about Panasonic KX T3281W Corded Phone (KX-T3281W)
A bank of blinking leds??
I have a Panasonic KX T3281 AL Corded Phone on my desk. Its more then seven years old. It has never had a problem.
I returned to my office this afternoon to find the bank of extension buttons on the right hand side blinking in unison. Nothing else has changed.
It dials both lines. Receives calls on both lines. Memory dials numbers.
But nothing I have done will stop the lights blinking.
I have cycled the power off/on several times allowing the unit to rest with no power for several seconds. When powered up the blinking just continues on. Help ! I'm and IT guy and know its trying to tell me something :-) but I don't know what!
Re: A bank of blinking leds??
The blinking LEDs means it need to have it's ID reprogrammed. Press the Program button and then the station number (Station 1 or 2 or 3 etc) to store the setting.
Posted on Aug 15, 2009
0 characters
3 Points
Hi I am working at the Switchboard. I have a Panasonic KX-T7730 that is seven years old. Every office has an extension code and a name. I want to change the display names of the extensions as it still...
This has to be done on Ext 101, or whichever phone is the programming phone. Press program *#1234. Then enter in 004. Press Speakerphone. It should be asking for a jack number. You can press speakerphone again to go to the first ext. Spell out the name using the keypad (2 is A, B and C and so on). When done press the autodial/store button. Then you can press speakerphone to go to the next phone. To get out of programming just pick up and hang up your phone or press the program button.
Aug 30, 2011 | Panasonic KX-T7730 Corded Phone
I used to have the Panasonic KX-T7630 system in the office building we sold. I no longer have the capability of setting the entire system up - is there a way to use the phone as just a regular desk phone...
The KX-T7630 is a proprietary digital phone that will only work on panasonic phone systems. You need an analog phone if you are going to connect it directly to an outside telephone line.
Jan 19, 2011 | Panasonic KX-T7630 Corded Phone
Station lights flashing
Other extensions may have DND active
Oct 27, 2010 | Panasonic KX T3281 Corded Phone (KX-T3281)
Make sure the Auto Answer button is not lit on the empty desk phone, then you could use either 40 to answer all calls, or 4+ the extension number to absolutely answer that phone.
May 06, 2010 | Panasonic KX-T7730 Corded Phone
Caller Id on phone
If you have it on other Panasonic phones, it should be automatic if the phone is made to ring.
If you don't have it, you need to call your Panasonic dealer. It requires hardware and programming.
Jul 08, 2009 | Panasonic KX-T7630 Corded Phone
I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Jun 11, 2009 | Panasonic KX-T7453 Corded Phone
Incoming calls
It is a programmable type phone, works only when power is available. Try without power..the button may not be necessary
Also try to change the setting for 'Line button'
Try to tell me.... whether my suggestion was useful???
Have a nice day.
Feb 06, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic kx-t7730
Hi this is normally a programmable control, operating only when the power is ON, try to disconnect the power and operate it
or else, reprogram it by using the manual...
Have a nice day.
Ring tone
Here is the instructions The full manual can be found here.
Oct 29, 2007 | Panasonic KX-T7633 Corded Phone
Panasonic KX T3281W Corded Phone (KX-T3281W) Logo
188 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
