Question about Micargi RD 269 Fixed Gear Single Speed Bicycle Flip-Flop
While assembling the seat we loosened the bolt to adjust the seat angle and the pipe fell into the bike frame.
How do we get it out???? my bike is not the flip flop its the fixed please help!!!
    Problem Solver:
  • 18 Answers
Turn your bike upside down, it should fall out. If that doesn't work turn it upside down and tap on the frame that should make it come right out.
Posted on May 03, 2015
How do I adjust the seat on Kulana Riviera 26" Ladies bike. It's too low.
There's a bolt near where the seat post goes into the frame. Loosen the nut, raise the seat (careful to note the max insertion line) and tighten the nut back down.
Jan 13, 2017 | Kulana Cycling
Tip
Identifying Your Reebok / Robix Studio Cycle
  • 9600
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and dual brake pads.
  • 9800
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and single brake pad.
  • 9900
    Glossy finishes w/angled back legs (stabilizer). Bolt-together frame (assembly required). Rectangle shaped stabilizers.
  • 2000B
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Silver crank arms and belt driven.
  • 2000C
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Black crank arms and chain driven.
  • 3000B Robix
    Black glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and frame down tube. Belt driven with single brake pad.
http://www.sportsmith.net/Categories.aspx?did=CEF96124-843A-4128-9B53-8E10980C9920
on Mar 11, 2015 | Exercise & Fitness
Tip
Indoor Cycle Seat Adjustment
Video of How to Adjust the Seat on your Indoor Cycle
  • This video will demonstrate how to adjust the seat on your indoor cycle properly
  • Tools needed:
    • Adjustable Wrench
  • To begin loosen the nuts on each side of the seat equal turns
    • Ideally, there should be equal portions of the clamp bolt exposed on each side
  • Once you have them loose you can adjust the seat back and forth on the mounting rails as well as adjusting the angle of the set
    • The best position for the seat is level and in the center of the mounting rails adjustment
  • Once you have the seat positioned as desired finger tighten the nuts on each side of the seat equal turns and then tighten the nuts using a wrench an equal number of turns as well
    • Again, the goal is to have equal portions of the seat clamp bolt exposed on each side
  • This is all that is required to adjust the seat on your indoor cycle.
Video of Adjusting the Seat on an Indoor Cycle
on Apr 28, 2014 | Exercise & Fitness
Apollo bike
by the bolt in the center (loosen it, then tap it, to free it up) that will allow them to go up or down. To change the angle of the bars the handle bar stem has 1 or 2 bolts facing the front wheel...loosen them and go where you need to go.then retighten them... happy Cycling.
em has 1 or 2 bolts
Jul 14, 2013 | Cycling
How to rebuild rear shock 2003 honda crf 450
Put the bike on a stand supporting the bottom of the frame. Remove the seat and sidepanels. Loosen the clamp on the carb to airbox boot at the rear of the carb. Loosen the muffler clamp, remove muffler mounting bolts and pull muffler. Remove the 4 rear subframe bolts. Remove the rear subframe (leave airbox and rear fender assembled in it). You are now staring at a completely exposed rear shock. Remove the shock mount bolts and remove the shock. Measure the spring adjusted length for a future starting point when the spring is put back on. Loosen both spring pre-load adjuster spanner nuts all the way. Helps if you clean the dirt off the threads and use a little lube. Pull the spring towards the spanner nuts and remove the clip ring at the opposite end spring holder. that's it.
See here
May 10, 2012 | Honda Motorcycles
Huffy mx 80 can you higher the seat.
Raising the seat is limited to how much seatpost you have available.
To determine the amount of seat height you have available you need to pull the whole assembly out of the frame. At the junction of the frame and seatpost there is a bolt, loosen that bolt and lift straight up and the assembly will come out. On the end of the seatpost where it inserts into the frame look for a limit line. Insert the assembly back into that line and that is the maximum height the seat can go.
If you need it higher you will need to purchase a new seatpost from yoiur local bike shop. Make sure you take them either the bike or seatpost as they come in many different sizes and they must match diameters exactly.
Dec 04, 2010 | Huffy Cycling
How do you adjust the seat
Hi there Vriddick
To adjust the seat for height, there is a locking bolt on the seat post, below the seat. Loosen this and the seat should drop down the hole. Lift it up to your specified height and tighten up the bolt. You can also use this method to adjust the direction of the seat in relation to the handlebars, left or right.
If you need the seat adjusted for its angle. Under the seat itself are two bolts clamping two large circular bits of metal, undo these bolts and tilt the seat downwards or upwards, retighten when you have it just right.
Jun 20, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
Dont know how to fit the seat to the bike
1. Tighten the bolt on the seat-post of your bike's seat if your seat is a bit shaky. You may need to replace this bolt if it is rusted or withered.
2. Adjust the pitch angle of your seat if it is uncomfortable. You can have it level, leaning forward or leaning backward depending upon what is more comfortable for you. Use an Allen wrench (Allen key) to loosen the bolt on the-seat post to adjust the angle.
4. Tighten the tension on the cover of the seat if the seat has one and it is loose. If it has 2 straps underneath the seat attached with a hook, release it from the hook and tighten, then re-hook the straps.
May 15, 2010 | Dynacraft 16" Boy's Wheels Bike
How do i remove the rear shock spring from my 2004 crf 250r
Feb 07, 2010 | 2005 Honda CRF 450 R
How to adjust saddle postions
you can loosen the bolt under the saddle, and adjust it...
for me, the best saddle position for long distance is when it's facing downwards a little bit, so that you can move your legs freely.
Oct 29, 2008 | Bravo Sports /Bike Access 1001782 Racing...
Micargi RD 269 Fixed Gear Single Speed Bicycle Flip-Flop Logo
236 people viewed this question
Top Micargi Cycling Experts
John Egan
John Egan
Are you a Micargi Cycling Expert? Answer questions, earn points and help others
