Question about Samsung DMT400RHS Builtin Dishwasher
Smart auto and delicate blinking, will not start, just making water sucking sound, but there is no water in it.
3108740697
Samsung dishwasher not pumping water out. "delicate" light blinking and it doesnt appear the pump even tries to come on. the machine just stops after wash cycle then I get the error light.
The Delicate light flashing on Samsung dishwashers indicates a drain error. Possibly a pump/motor assy.
Samsung Dishwasher Not Draining
Doesn't sound like a clogged ECS because it's not draining at all.
Jun 12, 2017 | Samsung Dishwashers
Samsun dishwasher blinking ligths auto normal and delicate
sounds like it wants you to tell it which cycle you want to use .try pressing just one LIKE normal
Apr 12, 2015 | Dishwashers
I have 2013 Dodge Grand Caravan while the car parked engin tanning start shaking and engin light blinking what cause this
You may have a serious problem. Take to An Auto parts store, they may run error codes and help understand what is going on.
I had a car that behaved very bad, turned out to be the air mass meter was bad.
Mar 18, 2015 | 2013 Dodge Grand Caravan
Kenmore HE3 starts by itself in "delicate" was cycle and fills with water when not in use. Can all this be caused by a bad selonoid??
Check that the machine is not on an auto delayed start. Strange that it starts itself. If a solenoid fails, 2 things happen. They either don't let water in at all, or they don't stop letting water in. If its not on an auto delayed start, I suggest that it could be a faulty main control board . You can stop the machine by turning the water off and switching the machine off at the socket when not in use.
Dec 24, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Samsung dishwasher when I turn it on it starts to fill up with water then it stops and the delicate light starts to blink
it looks like pump in your dishwasher try to unjammed by hand .make sure power is off when you work on it
Nov 24, 2014 | Samsung Dishwashers
Low water level
Try to unstick the float. The float tells the DW how much water is in it at any given time. It is shaped like a mushroom on the bottom of the DW basin. Gently pick it up and set it back down. Does it seem free? Try the cycle again.
Jan 10, 2014 | Samsung DMT400RHS Builtin Dishwasher
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
Lint on the clothes. The machine has an automatic lint filter. How do I get rid of this problem?
automatic lint filter means it goes out the drain when the water drain, nice how they make that sound all fancy huh. make sure there is more water than clothes and whatever your washing is not delicate you have to wash delicates with the delicate cycle
Jul 28, 2010 | Westinghouse Washing Machines
Kitchenaid dishwasher sucking noise when ON
the sucking noise is the water valve, opening but it doesn't not sound it getting any water in. have the water valve replaced.
do you get any error messages on the display?
Sep 13, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Samsung DMT400RHS Builtin Dishwasher Logo
191 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
