Question about Zanussi Washing Machines
Why isn't my washing machine starting? I start a program but nothing happens. Problem occured when the machine was doing a program and suddenly stopped with water still in. The fuse went while washing
Model: F 1206 There's light inside the buttons panel. I have tried all the programs and no one works. The fuse went when the machine washed. The machine is 11 years old. Used regularly.
    Genius:
  • Zanussi Master
  • 1,585 Answers
Check heater element
Posted on Apr 18, 2015
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
Why won't washing machine start?
It is most probably the door sensor that is faulty. If the sensor does not sense the door closing the machine will stay in "open door" mode and will not start with it's program.
If the machine is still under warranty, take it in for repair or have someone check it out for you. It should be a quick fix, if parts are available.
May 24, 2014 | Washing Machines
Ariston avxl 140
Check that you don't overload the machine. This can happen if the load is too heavy.
Jan 31, 2014 | Washing Machines
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 07, 2011 | Bosch WET 2820 Front Load Washer / Dryer
My machine stops at "delay start", yet the cycle is not complete.
PROBABLY NOT USING ((((H E DETERGENT) REASON FOR ERROR CODES,, POUR A SMALL AMOUNT OF COOKING OIL ON A SPOON AND POUR INSIDE SHOULD SOLVE PROBLEM
Nov 29, 2008 | Hoover AAA160 Front Load Washer
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Ariston LBE12X will not fill
depends which program you started with if you started with drain or spin then the humming noise you heard is the pump energised but jammed. remove the filter again and check nothing stuck in the pump impellor - bits of bra wire are the favourites if you started with a wash or rinse program, the humming noise is the inlet valve energised but no water coming thro. check water is turned on and hoses not kinked
May 22, 2007 | Ariston Technologies LBE12X Ariston
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
