Question about ASUS Computers & Internet
Asus m32 loud fan
Fan speed increases for no reason.
  • ASUS Master
  • 4,134 Answers
Fan speed does increase for a reason.....heat. Check you BIOS settings and verify that the CPU temp is not getting too high. Desktop computers are dirt magnets. It is common for the CPU heatsink to get clogged with dust and dirt. This will reduce cooling and increase heat, eventually to the point that the fan will speed up. Get some electronic duster (canned air) and blow out the fins on the CPU heatsink. DO NOT remove the heatsink from the CPU. There is a special compound that is on the heatsink surface that allows proper heat transfer from the CPU. Removing the heatsink means that this compound is disturbed and would need replaced. Most users do not have this compound and thus should not remove the heatsink to clean. If the heatsink is so clogged that you cannot get the dirt out with canned air, you may be able to remove the fan from the heatsink, depending on the fan/heatsink design. Then you can use a brush to get into the fins to clean them.
Posted on Apr 18, 2015
Asus m32 rebooting randomly
Check to see if your PC is over heating which would normally cause the fan speed to increase. Overheating will cause it to shut down unexpectedly. Cleaning all the dust from the power supply and vents will prevent overheating. Make sure the fan IS running.
After you back up your data, run disk diagnostics on the hard drive to fix any bad sectors.
Nov 05, 2014 | ASUS M32BF-US005S Desktop
Latitude e6500 runs hot how do i boost the fan
You may need to clean the fan and heatsink of dust. See the dust restricts the cool air from reaching the heatsink and this in turn causes your fan to spin faster. The computer's BIOS is programmed to increase CPU fan speed as CPU tempreature increases. If your fan is very loud, then it is running at the maximum speed possible. A clean heatsink will decrease the Processor's temperature.
Installing additional fans in your computer's chassis is an effective way of bringing the temperatures down. Install the biggest fans that your chassis supports. 120mm fans are better than 80mm fans as they can spin at slower speeds to provide the same airflow of a smaller fan. Therefore giving you a quiet computer.
Use a program called Speed Fan to ensure that your fans are indeed running at the desirable level of 100%
Take care!
damnor01
May 12, 2010 | Dell (6F858) Cooling Fan
Loud noise in front end at 35-55mph. Sometimes gets softer at around 65mph. Loud humming noise that increases in pitch as the speed increases. Noises persists when engine off and the manual transmission...
Electric cooling fan bearing failed and the cooling fan needs to be replaced. Start with inspecting the cooling fan behind the radiator and determine if that is where the noise is coming from. Replace any worn or damaged parts.
Thank you for using fixya and be safe.
Apr 30, 2010 | 2001 Chevrolet Cavalier
My computer fan speeds up whenever I'm on the
Nothing ... probably ... your fan speeds up when the processor temp goes up ... the more you are doing, the more cooling you need. The processor is calling for more cooling so the fan runs faster.
If this is a concern for you, you may wish to consider adding another fan to your case. In any event, make sure your power supply fan is clean. Use a vacuum or canned air to clean.
Mar 14, 2010 | Dell OptiPlex GX270 PC Desktop
ASUS Lap top computer, 2 months old' makes loud fan type noises at each start up.
Hi
Its normal for a laptop computer or a desktop computer to spin its fans at maximum speed during start up - its part of the power on self test.
If the fan is very loud like on this video the sound is very bad -
that would be a bad fan, constant bad noise. but if your fan only makes noise in start up, its normal.
your warranty should cover the replacement of the fan if its bad.
Oct 02, 2009 | ASUS Z71V Notebook Computer - 15.4"...
Asus M2N-E SLI
In my experience, there are some fans that are loud. It could be bad bushings or possibly a fan that is out of balance. The Cool and Quiet utility will not solve that problem.
Are you sure it's the CPU fan?
If the computer (or it's parts) are less than a year old, they should be under warranty.
If it's the case fan, I'd replace it with either a new single-speed fan or one that has a variable speed adjustment.
Apr 06, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Will i have to increase my fan speed?????
Hey,
The fan speed of the video card is controller by the bios on the card or by the driver used by windows.
You can try asus smartdoctor and see if you can adjust it on that.
but looking at the picture of the product you have selected, it would seem this one has a passive cooler, no fan.
But have a look at Asus SmartDoctor and see if that fits your need. http://www.asus.com/999/html/share/2/icon/11/index.htm
Thanks,
Ekse
Feb 20, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Engine revs realy loud
You have a faulty thermostatically controlled fan clutch. Same thing happened to mine. As soon as you start the car, the fan is always turning, and the speed increases as the RPM is increased.
Oct 19, 2008 | 2006 GMC Envoy
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Main cpu fan high speed
the speed of the cpu fan will go up and down depending on the work load that your pc is going thru,lets say you start a game and the speed increases then drops down thats all normal
Oct 06, 2007 | ASUS 865G (MBAS-P4P800VM) Motherboard
Computers & Internet Logo
328 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
