Question about Royal 1200MX 12 Sheet Strip Cut Paper Shredder With Basket
Makes grinding noise and does not pull the paper in or shred. I have pulled out all bits of paper stuck between the teeth. I'm afraid this thing is toast
    Top Expert:
  • Royal Master
  • 40,473 Answers
This type of shredder can get clogged so badly, the material has to be removed with a utility knife. This is especially true if someone has tried to shred coated stock or, worse yet, credit cards. The noise you are hearing is the mechanism bouncing over clumps of residue jammed in-between the grinding "teeth".
Posted on Nov 05, 2016
  • 883 Answers
SOURCE: Turns on when paper in slot, but won't pull it through to shred.
must disassemble feeder unit. you will find many bits of shredded paper to pull (push) out with a long narrow tool like a crochet needle.
Posted on Jun 19, 2007
SOURCE: royal rl 170 mx
We bought another shredder
Posted on Sep 17, 2008
  • 35 Answers
SOURCE: Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Posted on Feb 23, 2009
  • 35 Answers
SOURCE: My shredder keeps running and won't stop in on/auto mode
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Posted on Mar 03, 2009
  • 1218 Answers
SOURCE: Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the this a number of times this will get the oil down into the cutting shafts.
Posted on Aug 22, 2010
Copier will not copy feed paper oeven try-justs makes agrinding noise
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Why is my printer making really loud grinding noise and will not feed paper or print
It sounds like a bit of paper is stuck somewhere in the paper feed route. Remove the toner cartridge and any other bits that pull out. Removable bits often have a green tag or finger grips moulded in to them. Do a careful check in the printer for any bits of paper or even a full sheet stuck somewhere. Carefully remove all rubbish and reassemble.
Dec 01, 2014 | HP LaserJet 1018 Printer
The paper is stuck
Run the shredder in reverse for a few seconds then unplug the unti to pull the paper out from the top. Flip the head over on a table or desk and use a needlenose pliers to pull the paper away from the teeth. Once you can see that there is no paper shreds left, put the head back on the bin and plug it back in. Caution, KEEP ALL LOOSE CLOTHING AND FINGERS AWAY FROM THE OPENING!
May 16, 2012 | Office Equipment & Supplies
Hi, my Nikon Coolpik S8100 camera lens seems to be stuck and not extending. When I turn the camera on, it makes a clicking sound and the lens does not come out. Please help!
try manually pulling on lens housing while powering on. if there is a grinding noise the gears are probably missing teeth.
Mar 21, 2011 | Cameras
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here:
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
I was shredding paper when it started making a loud grinding noise and wouldn't accept any more paper. I've tried running it back and forth, but it only goes, maybe half way, either way, and it still...
This is a very common problem. Go out to the hardware store and buy some silicone spray. With the shredder unplugged, spray a good amount of the silicone inside all of the teeth and try to get all sides.
Plug it back in and work it back and forth a few times. It should work better with less noise now.
Jul 24, 2009 | Fellowes DM15C Shredder
Aluminum key stuck in teeth of shredder
If you can get the top cover off by removing the 4 screws, you can manually turn the motor in reverse and pull the key out.
May 17, 2009 | Fellowes Office Equipment & Supplies
May 01, 2009 | Royal VF1000MX Shredder
REALLY loud grinding noise
If it doesn't work at all, there is a reset button for the unit. After it is reset keep the cutters lubed.
Jul 16, 2017 | Royal CIA 12X Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
Royal 1200MX 12 Sheet Strip Cut Paper Shredder With Basket Logo
232 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
