Question about Sub-Zero 690 Side by Side Refrigerator
The 3 lights on refrigerator side don't work.
When I put the lights on the freezer side they work, what do I look for.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
You may have a defective door switch. The switch has a paddle that is depressed when the door is closed to turn the lights off. This switch can easily fail or sometimes, the paddle does not deploy to turn the lights on. This could be due to gunk built up on the paddle. More than likely, the switch has failed.
Posted on Apr 25, 2015
2 Suggested Answers
  • 9 Answers
SOURCE: Lights all went out in refrigerator side of Sub Zero 632
I WILL BET THEY ARE DISCONNECTED !!!! CHECK FOR CONTINUITY AND SEE WHERE THE CONNECTION IS OUT.
Posted on Oct 13, 2012
Kitchenaid refrigerator control panel
Light switch has gone bad use your model number to order a new one
Jul 25, 2013 | KitchenAid Refrigerators
No light, no cooling in refrigerator, but cold freezer Americana A3316ABSDRWW
This usually means you have ice build up between the two units. Defrost the freezer and if possible let it sit to completely thaw all ice from the channels that allow cold air from the freezer to move to the Refrigerator side. You will also want to check your door seals to make sure you don't have any leaks or a bad seal causing your issue. The issue with the light is most likely a burned Bulb or bad switch. Replace the bulb and see if that resolves the issue. You also need to check and make sure the fans are working properly which move the air from the freezer to the refrigerator side and that all the cooling grill son the unit are clean and not clogged with dust build up.
Nov 25, 2011 | KitchenAid Refrigerators
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Freezer side of my RS2534WW Samsung is not working, fridge side is fine, evap coil fan is running,,, what could be wrong , it's only 7 years old
Your indications does not make sense! Your unit has ONE compressor that uses ONE evaporator coil to cool both sides. So if the FREEZER side is not cooling the fridge side should not cool either! Are you sure you don't have the freezer and refrigerator sides reversed?
Aug 14, 2011 | Samsung RS2534 Side by Side Refrigerator
Frigidaire side-by-side model GHSC39EJPWO. Light in frig don't work, tried changing bulbs; didn't help. I cannot find the light switch - where is it located? I have examined everywhere!
I too am very perplexed by that i have looked at the parts breakdown and see a switch for the freezer in the side wall but no switch for the fresh food section. I have included the link for the parts breakdown i was looking at, the freezer light switch is item# 14A
http://c.searspartsdirect.com/lis_png/PLDM/R0804082-00003.png
Good luck
Gene
Aug 02, 2011 | Frigidaire Side by Side Refrigerator 26...
The evaporator fan is blowing the freezer works fine but the frige don't,?? what else can i check?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Hotpoint-Ariston HSS22GFTWW (22.0 cu. ft.)...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Sub-Zero 690 Side by Side Refrigerator Logo
93 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
