Question about Toshiba Satellite Computers & Internet
How to format windows 8 on he on a pre installed windows 7.
I don't have a working disk drive
  • 3,961 Answers
You don't 'format' Windows, I believe you mean install it. The disk drive you mention I think is a CD drive. This makes it a bit more difficult to install W8.1 (don't get W8.0, you will only have to update it), but it is possible, by downloading it. However not all PCs can successfully run W8.1 - See here first
http://windows.microsoft.com/en-au/windows-8/upgrade-from-windows-7-tutorial
Posted on Apr 18, 2015
Format hard disk C of netbook
Important: It is recommended to take a backup of all the necessary data you have on your C: drive before you format it. Formatting the drive will erase everything on it.
The steps to format hard drive can vary depending upon which version of Windows you are using. You can refer to the following links for instructions:
For Windows 8 / 8.1:
http://pcsupport.about.com/od/windows-8/fl/format-hard-drive-windows-8.htm
For Windows 7 / Vista:
http://windows.microsoft.com/en-in/windows/create-format-hard-disk-partition#create-format-hard-disk-partition=windows-7
GuruAid.com
Feb 26, 2015 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
I had Windows 8.1 istalled in my Pc but it showed problem now i want to install windows 7. I have windows 7 bootable USB and want clean instalation. i booted from USB and opened stup and formatted my
Simply formatting the hard drive does not remove all residual traces of the previous installation. When you get to the step for formatting, go to the advanced button and delete the partition that contained windows 8. Then create a new partition in the space, format, and install windows 7.
Aug 05, 2014 | Computers & Internet
Laptop came with windows 7 factory installed on it. A friend accidently formatted the hard drive.
Either download an installer disk on to a DVD or partition a harddrive with an installer disk on it. Boot from that disk and restart the computer, it should boot up and ask to install Windows 7.
Dec 01, 2013 | HP Computers & Internet
Driver for norwood micro dual format dvd recorder
the drive does not need a driver however it may need a firmware update.
Jul 06, 2013 | Dual Norwood Micro Micro Format DVD...
My hpv165w 4 gb pendrive shows empety
Format the usb key with HP USB Disk Format Tool.
Then download Universal USB Installer (Pendrive Linux) which has support for booting/installing Windows Vista, 7, and 8
Mar 29, 2013 | PNY HP P-FD4GBHP165-EF BLUE HPV165W USB...
How to install wins 8 on dell Inspiron netbook 1018
proceed according. God bless you
  1. Create a New Partition
    • 1 Launch the Disk Management tool on your computer running Windows 7 by opening the Start menu and typing "diskmgmt.msc" in the search bar. The Disk Management tool, showing all connected storage devices, appears.
    • 2 Pick the hard drive onto which you'll install Windows 8. The normal choice is Disk0, which is the primary hard drive. This disk should already show your C: drive, and possibly other items like recovery partitions.
    • 3 Verify the available free space on the selected disk. For most computers with no other dual-boot setups installed, the entire drive should be occupied, so you'll have to shrink an existing drive (like C:). If there is a section with a black bar titled "unallocated," then this represents free space not currently in use.
    • 4 Shrink your C: drive by right-clicking on it and selecting "Shrink Volume." The computer assesses and reports how much free space is available on the disk. You need a minimum of 16GB of free space to install 32-bit Windows 8 and 20GB of space for 64-bit Windows 8. Type either 160000 or 200000 in the "Enter the amount of space to shrink in MB" box. Increase that number if you want additional storage space for files and programs within Windows 8. Click "Shrink" to continue.
    • 5 Right-click on the new unallocated space and select "New Simple Volume." Leave the defaults, ensuring that NTFS is selected as the file system type. Give the drive a name, like "Windows 8."
    • 6 Insert your Windows 8 installation disc or USB drive into your computer. When the new drive is formatted, restart the computer and boot from your installation disc or drive.
    Install Windows 8
    • 7 Select "Custom" during the Windows 8 Setup initialization process.
    • 8 Select the new drive you created when the installation program asks you where you want to install Windows 8. Be sure to select the drive with the label you used for the new drive; if you install to the C: drive, you will overwrite your existing Windows 7 installation.
    • 9 Follow onscreen instructions to install Windows 8.
    • 10 Reboot after you install Windows 8, ensuring that you've removed any installation media. When the computer restarts, you are presented with a boot screen that lets you pick between Windows 7 and Windows 8.
Oct 18, 2012 | Computers & Internet
I have ask you already how to install the dual boot os(Windows xp and Windows 7 ), but i don't complete yet .Can you explain to me again step_by_step in great detail ? because when i install windows xp...
Hello, this is how I dual boot my laptop with windows xp and windows 7
1. Backup all you important files, use an external hard-disk if possible
2. Make sure you have two drives or partitions: usually drive C and D
3. Insert your xp cd, do a quick format of drive C and install
4. Boot into windows xp and format format drive D if necessary
5. Insert your windows 7 DVD and follow the prompts. When it asks you to upgrade or new install, choose new installation
6. When you are asked to choose a location choose drive D
7. Complete your windows 7 installation
8. Thats it, you can now install drivers and programs
When installation is complete you will see both os options: windows 7 and previous version of windows (i.e xp)
I have done this numerous times without the need for any other step or software. The only rule is to is to install xp first, then windows 7.
All the best
Jul 11, 2011 | Computers & Internet
My cd/dvd drive G:\ (hl dt st rw dvd gcc h21n version.1.00) does not reads windows 7 dvd .. and it only reads cd-r/cd-rw.... plzzz help i want to install windows 7... plzz help...
It sounds like your drive is having issues, you can always install windows 7 from a flash drive (so long as your computer supports booting to one). Instructions on setting this up are here: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/ You will need to do this from a computer with a working DVD drive to transfer the info to a flash drive.
Jun 28, 2011 | Computers & Internet
RES.SIR, PLEASE TELL ME HOW TO ADD(INSTALL) THE MISSING FILES OF OPERATING SYSTEM TO RUN WINDOWS PROPERLY,WITHOUT FORMATTING CONCERN DRIVE.PLS PROVIDE THE PROPER PROCEDER. THANK YOU.
Hi
Use the OPERATING SYSTEM CD/DVD to run the REPAIR MODE.
REPAIRING THE OPERATING SYSTEM just load or install corrupted or missing files from your operating system thus will not delete any of your files from your computer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 23, 2011 | Computers & Internet
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
