How to open the machine and fix the belt on it
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Remove back cover
Posted on Apr 18, 2015
Won't agitate
take out plug open at rear and you will see where to put the belt
Jan 06, 2014 | Fisher and Paykel GWL11 Top Load Washer
How do I open the case to fix the belt on my Brother LS 2160 Sewing Machine?
Open screws that attached to casing then open front cover of the casing.
Aug 29, 2013 | Brother LS 2160 Sewing Machine
The belt fell off the pulley .... How can I open the machine to have it fixed ?
unscrew the bottom panel and work the belt back on by putting on the small spindle first then loop it around the big wheel as much as you can. Then rotate the big wheel slowly with one hand while working the belt on with the other. go to you tube in type in "how to install a bread machine belt" there are several videos there. It's pretty easy to do once you view the videos.
May 08, 2012 | Sunbeam 5891 Breadmaker Home Bakery Bread...
E2 error message
I have brother sewing machine CE 4000, it became jam, I opened the machine & tried to rotate it with hand, I took out the belt, it became easy to move, again fixed the belt, but now it does not turn on, may be the timing of belt has disturbed, it shows Er2, how to fix it.
Dec 09, 2011 | Brother CE4000 Computerized Sewing Machine
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
My washer had stopped spinning about two weeks ago, we replaced thecoupler and it worked fine but today it stopped spinning again
5
6
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Washing Machines
How to open hotpoint wf440? our machine is not spinning but the engine is working fine. opened the lower back and the belts have fallen off. what could be the problem and how can we fix it? help me...
well you have found the problem the belts have fell off,
now how to put this wright? take the back off or the top, pull belt over all the drive pullys and the job's a good un! thing is, what caused the belts to come off in the first place???? most likly to be the motor adjuster ie: the spring! has come loos letting the belts slip off the pullys
Oct 17, 2009 | Washing Machines
Belt on a hotpoint wf250
open it up, see wat thensions the belt, loosen that up and fit new belt. retension
Apr 19, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Belt came off
well that is very nice idea you can fix with your self provide talls most commonly use.Set of screw driver,open and socket wrench,pliers etc...Remove the top cover plate by loosening bolt holding the cover and cover besides the handwheel where the motor was installed besure it was unplug from ac source(No power)Check the motor holder that attaching from casing.You can see the motor coupled by the belt.In the motor holder there is a bolt slot adjustment for tensioning belt tighning and loosening.If you want to disconnect the belt and replaced loosen the tension and pull out the belt.Sometime belt are sliping to the pulley it affect
the sewing machine operation,you can tighten from adjusting the tension of the belt.adjust not so tight after adjusting try to run manually first by turning handwheel freely if the motor will run freely with out obtruction no power supply.If your satiesfied try to run with power supply but jag twice first to be sure no problem occured before continous operation.
Mar 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Machine will not agitate
most likely it's either a broken belt, or the motor is going out. to check it you need to take the outside casing off, not sure exactly how to do that on that model. Anyway open it up, check under the drum for a belt, if the belt is in tact than it's the motor, in which case. Personally I wouldn't put in the effor to replace. as to where you can get a belt if it is broken, I don't know that either. Good Luck
Jun 20, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
