Front load washing machine won't open, it's locked with load in it.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Remove lid can b opend with a long screw driver to push door strike to side replace door inter lock and door catch
Posted on Apr 18, 2015
SOURCE: Front Load Washing Machine
Filling laundry detergent and/or additive
dispensers
Dispenser I: (RIGHT SIDE)
Detergent for soaking agent.
Dispenser II: (LEFT SIDE)
Detergent for wash, stain remover.
Dispenser 2: (MIDDLE)
Cleaning product, e.g. fabric softener, fabric
conditioner (do not fill above the lower edge of the
insert 1).
Posted on Feb 16, 2008
SOURCE: euro tech front load washing machine
YOU CANNOT RESET ERROR CODES ON APPLIANCES BY MERELY UNPLUGGING THEM FOR 5 MINUTES. MOST MANUFACTURERS RECOMMEND AT LEAST 30 MINUTES IF YOU GOING TO ATTEMPT TO TRY TO RESET A COMPUTERIZED CONTROL BOARD. STOP POSTING THIS INFORMATION INCORRECTLY.
Posted on Sep 30, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
TheMobilian
  • 8220 Answers
SOURCE: sumsung J845 front load washing machine cannot open the door
What you need is a Samsung service repair manual
Posted on Mar 03, 2010
Testimonial: "Thank you for the manual, it helps me take off the top cover, but I am still in the same problem. But thank you all the same"
  • 414 Answers
SOURCE: bosch front loader washing machine door not opening
The door will not open if the machine detects excess water in it. Run the drain or spin cycle to check if water is being expelled. If necessary check the pump filter for obstructions and the outlet hose for blockages. If this does not work you may have a problem with the pressure system, the door lock itself or a crack or break in the handle and it is not catching the lock mechanism, let me know if this helps or if you need further assistance.
Posted on Nov 24, 2011
My Bosch AvantiXX front load washing machine has finished the wash and now it has locked on me and I can't open it. How can I open the door?
hi Suzanne.
i have had a look around the internet and found that there is lots of ways to try and open it.plus there is people on youtube showing how to open a door.
so if you go to this link and pick the one you think would be the best one for you to try.
Bosch AvantiXX front load washing machine door wont open Google Search .
or this one.
How to open washing machine door that won open normally
Nov 20, 2017 | Bosch Washing Machines
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
Can't open door
the two possibles are faulty door lock or water still in the machine. the error code should tell you which. go to AEG and their troubleshooting page will give you the codes.
Jan 30, 2013 | AEG Lavamat 72640 Front Load Washer
E42 error code electrolux washing machine
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Thanks!
Dec 20, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
Jun 08, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
