Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Low power savin mode on Sony TV - Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I reset fuser code on savin 2513 with a sc544. I have checked the fuser lamp thermal fuses etc. From the power source in cable unplugged. The thermistor reads about 390 k ohms at room temp. It had a...
When reading the thermistor, grasp the sensing part between thumb and forefinger, if reading drops quickly the thermistor is probably goid, if so , unfortunately you may need a power supply board
Feb 12, 2015 | Savin Office Equipment & Supplies
I have a Savin 8035e. I had an error code SC542 and reset the copier as suggested. Worked great. Problem now - How do I fix alignment?
That error code is a dirty fuser thermistor. Clean it and go into service mode then turn off main power switch. That is all that is required. What is out of alignment?
Oct 10, 2014 | Savin Office Equipment & Supplies
SAVIN C7570 BLACK INK PRINTS FADED (INCONSISTENT)
Hi Linda
Is this ink or toner? Ink will expire if it is on a shelf too long. Toner is a powder that is applied with heat to the paper. It does not expire but will appear faded if the printer is in economy mode or low on toner. on a 4 drum system each drum is independent of the others and can run low or out at separate times. Therefor to save money only replace the empty drums. Have you changed the drum recently? If it is toner try removing it and shaking it, then reinsert it. If you have other boxes of this drum see if you can find a date on the box. ink over three years old may not work well.
Apr 28, 2014 | Savin Lanier Ld275c Lp138c C7570 4 Drum...
I have a savin 8045. I am getting an error code sc545. I just replaced the roller is the code related to this and how can i fix it.
The Thermistor (the heat sensor that rides on the teflon coated roller) is out of position or is unplugged.
Once it is repositioned or replaced the code must be reset. To reset it, push the Clear Modes key, then 1, then 0, then 7, and then hold down the Clear/Stop button until the screen changes. Once it changes select the System SP mode (the top one). Now turn off the main power switch. The code will be reset once you power the copier back on. Leave the front door open when you power it on. This will tell you if it reset the code. If the code is still there you did not reset it correctly.
Mar 09, 2011 | Savin 8035e Copier
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
