Question about Bosch TASSIMO Coffee Makers & Espresso Machines
Bosch Tassimo element
Can the heating element be easily replaced?
    Top Expert:
  • Bosch Master
  • 48,512 Answers
Not really they do not make many things repairable but throw away sells more machines that way
Posted on Apr 18, 2015
Tip
Common heating faults with Bosch HBL 5052 double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 5052 Electric Double Oven
My Bosch Caddy Tassimo coffee maker works but only dispenses cold water
heating element has failed .many coffee makers do not have parts that we can replace tho
Mar 05, 2017 | Bosch Coffee Makers & Espresso Machines
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Tip
Common heating faults with Bosch HBL 5056 double oven
on Jan 19, 2010 | Bosch HBL 5056 Electric Double Oven
Tip
Common heating faults with Bosch HBL3420UC Electric single oven
on Jan 19, 2010 | Bosch HBL3420UC Electric Single Oven
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
Tip
Common heating faults with Bosch HBL 5032 single oven
on Jan 19, 2010 | Bosch HBL 5032 Electric Single Oven
Tip
Common heating faults with Bosch HBN 560570B / 560550B single oven
on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
Tip
Common heating faults with Bosch HBN 442 / HBN446 single oven
on Jan 19, 2010 | Bosch HBN 442 / HBN446 Electric Single...
Coffee Makers & Espresso Machines Logo
146 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
