Can't open front door - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 45,291 Answers
Sorry but without a make and model we have no idea where to look for an answer
Posted on Apr 18, 2015
How do you open the front panel to check the brushes
  • Open the door
  • Pull out the mains plug
  • Remove the metal ring around the door opening seal (apply pointed pliers to stretch the spring beneath the door opening)
  • Push back the seal from the front panel
  • Loosen the two door opener screws
  • Remove the plinth
  • Remove the two outer upper screws behind the plinth
  • Remove the bolt right underneath the door opening while supporting the front panel
  • Gently lower the front panel and take it away
If the brushes are all right, then probably the electronic is defective.
Check for our repair service at www.youfixit.eu.
Jun 30, 2014 | Miele Novotronic Premier 500 Front Load...
Front Doors LOCKED OPEN.. How to close?
Lift the door handle as if you were opening it
Hold the handle & use a round phillips to hook
& rotate the white door latch to the open position
May 18, 2014 | 2009 Honda Odyssey
Central locking 2005 subaru liberty stopped working on 2 doors
1. Replace battery in remote
2. Replace sensor at rhf door lock (it is inside of door)
Apr 30, 2014 | Cars & Trucks
Interior courtesy light
Page 116 and 117 of the manual explain that there's a two-position slide switch on the map light, DOOR and OFF. The back light has three positions, ON, Door Activated, and OFF.
Pages 116 and 117:
http://techinfo.honda.com/rjanisis/pubs/om/ACC080/ACC0808OM.pdf
Dec 12, 2013 | Honda Cars & Trucks
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How does front panel come off (safely) to swap out door switch on kenmore washing machine 41744152400
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
Mar 11, 2010 | Frigidaire ATF6000ES Front Load Washer
How to remove the door panel on a 96 Ford Thunderbird?
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Remove front door trim panel retaining screw through front door trim panel finish panel opening.
Remove interior lamp lens cover.
Remove screw through interior lamp opening.
Slide front door trim panel upward to disengage hooks.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Disconnect window regulator jumper wire
Remove front door trim panel.
Feb 21, 2009 | 1996 Ford Thunderbird LX
Front Doors Won't Open?
Hyundai sonata have small spring about 3 cms long which corrodes and brakes. When this happens you cannot open the front two doors. you have to unfortunately cut a hole in the door trim and open the door by realeasing the latch with hand and then replace the spring.
Oct 03, 2008 | 1997 Hyundai Sonata
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
