Question about Garden
Change pull cord on this petrol strimmer - Garden
    Top Expert:
  • Garden Master
  • 44,436 Answers
Sorry but without make and model we have no idea
Posted on Apr 18, 2015
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
Recoil pull cord wont retract.
Buy a new part unless your capable of taking apart the motor and restring it
Jun 28, 2014 | Sony PlayStation 4
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
My petrol strimmer which is quite new, stopped. i let it cool down, but i cant restart it as the cord will not pull out. can you advise please?
I fear the engine has seized, you need to remove the muffler and check the condition of the piston through the exhaust port.
Jul 01, 2011 | Garden
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
How to sort broken pull cord on petrol strimmer
Hi Baz, i will tell you a generic way of doing this as i don't know the model of your strimmer.
on the pull cord housing you will have 3 or 4 screws to secure the housing to the motor body, undo these. the housing will lift away from the main motor body, underneath this cover you will see a spring canister, there may be a screw or clip keeping this in place or some are just secured with the outcover. remove this canister you should see a coil spring in the middle and a groove around the outside where the cord goes. you should see a knot inside the cord grove where the cord is threaded through to secure, remove thisand remove old cord. Now the trickky bit! some times it helps to have a helping had, you will need to turn the coil spring so it tights up to its full tightness, then thread the new cord into the secureing hole where the old cord was located, then when you release the spring this will coil the cord round the cord groove. replace the pull handle on the end of the cord so there is no slack and replace on to motor in reverse order. Hope this helps.
Sep 04, 2009 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
I need a manual for aoleo mac 730s strimmer
Petrol oil mix 25:1 or 50:1 oleo macs own
Starting lock trottle half way (put On/off to start position and depress lever ) prime bulb x 5 choke back fully and pull chord till starts
plug rcj-7y
Apr 03, 2009 | Garden
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
