Monitor don't turn on
I found short diode behind the board exactly under PWM ic.it was smd zener diode and h2 typed on it. i dont know how much voltage it have to replace it with one another. if any one have service manual or datasheet for this monitor or board please link me. monitor model is eizo scanflex s1932
  • Computers & ... Master
  • 15,941 Answers
Http://www.eizoglobal.com/support/db/products/manual/S1932#tab03
You should contact EIZO about that. Also I hope that you removed that diode to test it.
Posted on Apr 18, 2015
  • edris
    edris Apr 18, 2015
    yes. i removed it and tested, it's short. thanks for your answer.
My PIXMA MP970 printer abruptly lost power. is it due to fuse problem and where is the fuse box?
Dear
The printer has the step down SMPS which supply the low voltage (generally 24V DC to the other component. It contains high voltage risk also the high frequency. Sound knowledge is required while repairing the SMPS also appropriate precaution. If somebody is present having electrical knowledge during repair is better.
First disconnect the electricity supply cable from the printer
open the smps, check visually for any physical abnormality of individual component, then check the fuse for open,if its open check the MOV,mosfet,capacitor,bridge/zener diodes for short if found replace with same value,
take a series lamp of 15W incandescent bulb, connect the smps, check the voltage at secondary output. utmost care should be taken with attention of co-worker while checking live circuit.
If there is no voltage, check primary component at area of PWM IC /replace PWM ic (smd).
Again FATAL ELECTRICAL SHOCK AND FIRE MAY HAPPEN IF CARE NOT TAKEN.
Thanks.
Feb 13, 2015 | Canon PIXMA MP970 InkJet Printer
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Jan 27, 2015 | Panasonic Televison & Video
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
Computer box
You supplied proprietary part identifiers for your unknown brand computer monitor. Without more specific details there is not much we can do to help
Jun 11, 2013 | Computers & Internet
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
What is the velud of these zener diodes Phillips 50" Model 50PF94310/37 Plasma
Try to download the service manual to this set by internet. It will have all details you want to know.
Aug 24, 2012 | Philips Magnavox 27MS343S 27" TV
Polaroid 860-AZ0-GF371H Power Supply Unit. After replaceing all bad caps and and shorted fets Q102,103 I still need to know the value of smd zener ZK2 in Parallel with 3 low value smd resistors. I think...
HZK Series
Silicon Epitaxial Planar Zener Diodes for
Stabilized Power Supply
open the following link and it help you it has all the detail about the mentioned diode
Aug 26, 2011 | Polaroid FLM-3232 Television
I have a proview lcd monitor model pl866s .What is the size of the power connector for the 19vdc @3068a psu?I have an extra psu with the correct voltage /current .Thanks Robert.
For the above LCD Monitor, I actually saw a small spark at the top part of the main board once the power input jack was connected. It prompted me to the exact location and when I check the SMD ceramic capacitor (that generated the spark underneath it) with analog meter set to X 10 K ohm range; it actually developed a slight short circuit. Replacing only the fuse and the SMD ceramic capacitor solved the no power problem in this 19" LCD Monitor. This Monitor uses the inverter IC (OZ960G), A1084-25CM (2.5 volts voltage regulator), AMC1117-3.3 (3.3 volts voltage regulator), ADC IC (MST8136B) and CPU IC (MYSON MTV312MV64).
Oct 07, 2010 | Proview PL 866s (Gray, Silver) 18 in. Flat...
Samsung lcd monitor 153V has no display power indicator (green) is ok found 1 ic AE3U1T burnt. is this ic available or has the psu and backlight panel pcb to be changed.. dtgandhi@gmail.com
Samsung 153V LCD Monitor Power Supply Repair Tips
Troubleshooting Samsung 153V LCD power supply is just like troubleshooting those CRT type. This monitor came in with no power symptom. If you are first time repairing this type of power supply, I recommend you to first remove the switch mode power transformer. Then test every single component in the primary section, before you continue to check the secondary section.
You have to be good in testing basic electronic components in order to detect the fault. You can always browse through my website just in case you do not know how to test basic electronic components. If you do not know the right way to check, you might miss out a bad component and this will lead you not able to solve the problem. After carefully checking all the components in the power supply section, I found the filter capacitor do not have any reading using digital capacitance meter (open) , the two round type fuse also open circuit, 1N4744 15 Volt zener diode short circuit and lastly the power IC TOP247F blown!.
Testing the SMPS (switch mode power supply) primary winding with a **** smith fly-back tester, shows green bar which indicates good winding. What we left here were the secondary diode and filter capacitor. Upon checking them with analog meter and ESR meter, found all of them to be good condition. Other area like main board and inverter board also looks okay (Power failure rarely affect these two circuit). Now we have confirmed that only five components found to be faulty.
One by one the components were replaced (except one fuse) and just before you switch on the power supply, make sure you connect a 100 watt light bulb across the live ac line. Once it is done you can then proceed to switch on the LCD monitor to look at the brightness of the bulb.
If it very bright, this suggests that there are still short circuit somewhere in the power section. If it dim or totally goes off, you can now place your red probe to the secondary side to check if any dc present at their respective line. If there are DC voltages present at the output, you can switch off the power, discharge the filter capacitor (for safety purposes), remove the light bulb and connect back the new fuse to its original location.
You are now hundred percent sure that the LCD power supply won
Mar 23, 2009 | Samsung SyncMaster 153V 15" Flat Panel LCD...
HP Compaq FP5315 15" LCD Monitor dead
yeah replace the caps and sometimes the 7.5v zener diode burns up too. I have been replacing the surface mount ones with just a regular through diode
Jun 11, 2008 | HP Compaq FP5315 15" LCD Monitor
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
