Question about Health & Beauty
DMA SCOOTER WONT MOVE ALTHOUGH BATTERY FULLY CHARGED
WAS WORKING FINE BUT AFTER RECHARGE WILL NOT MOVE
    Sergeant:
  • 313 Answers
Are there any fault codes, flashing light. Check your user manual in the trouble shooting guide.
Have you disconnected charger from scooter as it will not move if it is still connected to scooter.
Posted on Jun 16, 2015
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
gewiz
  • 1263 Answers
SOURCE: Battery fully charged, buzzing sound when i try to
check the FREEWHEEL LEVER at the rear of buggy to make sure it in the drive position, if you can push the buggy it not in drive mode.
Posted on Jun 13, 2009
  • 17 Answers
SOURCE: the battery is fully charged but the scooter will not move.
Is it the small portable scooter? The one with the base that comes apart for transporting? Could it be a bad connection where it goes back together?
If it is the portable, try disconnecting the rear drive portion from the base and re-installing it so it clicks into place.
Posted on Sep 22, 2009
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
SOURCE: won't move lite on battery fully charged
I had this problem with the Cosco 4 wheel scooter. It turned out that one of the primary power lines under the shroud (back housing cover) was loose. It was not disconnected -- just loose. Apparently the loose connection would support enough current flow for the diagnostic circuit, but not enough to move the scooter (similar to using too small of a wire gauge in its effect). Once the power cable connector was tightened down so that the cable would not rotate on the connector, everything worked correctly.
The same symptoms could also be caused by a faulty power cable. If you have access to a multimeter, test the resistance along each cable path. If a path has an unusually high resistance, compared to the others, start to look for problems there.
Posted on Aug 31, 2011
Batteries for strider full, but wont move brake appears to be on.
Hi how did u test the batteries.the only accurate way to test them is to use a BATTERY load tester ...u can buy them on E/BAY.APROX COST $35::.cheers
Jul 05, 2016 | Electric Strider Midi 4 Wheel Mobility...
Merit dma mobility scooter
hi, okay so you got a onboard charger ? right there should fuses fitted to either on of the three wires coming out of the charger ? unless the charger is itself is faulty ?
Regards
Rob
May 04, 2014 | Health & Beauty
It won't move when battery is fully charged
only guessing but today I fixed one with this problem by spraying the speed potand connectors under the top with radioshack contact cleaner/lubricant.now scooter runs fine .
Dec 26, 2013 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Although the battery is fully charged the scooter will only move very slowly
usually their is a speed control knob on the control panel, try turning this up ?
Jul 19, 2011 | Health & Beauty
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
The scooters won't start although lights and horn workd
mcdevito75 here, Is the battery fully charged, if not, Charge battery, if Charged double check connection at battery and motor.
Jun 24, 2010 | Electric Mobility Mobility Electric Power...
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Oct 29, 2008 | Pride Sonic 3 Wheel Portable Scooter
Health & Beauty Logo
160 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
