Question about Samsung GALAXY S4
Need 4 digit code to pair to my 2004 e class - Samsung GALAXY S4
  • 4 Answers
What ever you are pairing with, the phone should just pair...
However, if it does not ... try "0000".
Otherwise look for documentation on line for the device you are attempting to pair with.
Posted on Apr 18, 2015
Pairing iPhone 4s with bp657875855
Sometimes you have to enter the pin manually. Most blue tooth pins are 0000 but some use 1234
Apr 09, 2014 | Mercedes E-class E320 E500 E55 Exterior...
Pairing Code for ASUS r503c?
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Nov 22, 2013 | Computers & Internet
Pairing code for dell wireless 370 bluetooth mini-card
Normally when pairing with any device, any pairing code can be applied (4 digits),and then when asked on the other system, the one applied on the first system, will be required to put in. In most of the cases, it is pre defined as 0000
Jul 06, 2012 | Computers & Internet
Just bought a used 2004 with handsfreelink. tried pairing my iphone 4 to it by following directions with voice commands and 4 digit passcode. system wouldn't pair and can't get radio on in any mode(cd,...
When you try to pair your iPhone 4, what message does the iPhone prompt you after you enter in the passcode?
Have you tried making sure your iPhone was disconnected from any other headset around you?
Mar 07, 2011 | 2004 Acura TL
Is Nokia Bluetooth headset CE0560 Type BH-607 compatible with iPhone 4 as it does not find it when searching?
Hello thee you must first make sure your blue tooth device is in pairing mode,to do this it usually means when you turn it on you hold the power button on for 6 to 10 seconds and it puts the device into pairing mode once they have paired you will need a pairing or pin code most manufactures use a 4 digit code they are as follows 0000,1234,1111,9999 i hope this helps if not refur to your manufactures procedure
Feb 21, 2011 | Nokia Bluetooth Headset Headset
How do i pair this bluetooth
you must put the device into pairing or discovery mode then search or add new device from your phone menu once they have discovered or paired you will need a 4 digit pin or pairing code ,Most blue tooth device manufactures use the following codes 0000,1234,1111,or 9999 i hope this helps
Feb 20, 2011 | LG HBM-310 Bluetooth Headset
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
Feb 18, 2011 | Jabra SP5050 Bluetooth Headset
I cannot connect my samsung solstice - it keeps asking for password to be sent
Your nav/bluetooth system will for the car will issue a 4 digit code in the screen of the car, this is a code which you input into the phones keypad.
.On an LS this is generally found by going into the info screen , then phone , then settings then add phone at this point the code for the car should appear often 1111 , 1212 , etc.
Your phone will have a Bluetooth enabling feature, under its tools or settings menu. You will be need to authorize the phone to search or enable new devices.Search" Hands FREE" should appear as an optional device and a pairing mode icon will be visible. The phone will search, indicate an item found and then prompt you for the 4 digit pass code on the cars menu screen. This code when input into the phone will clear the transfer of a connection between the car and phone.
Nov 24, 2009 | 2004 Lexus LS 430
Samsung GALAXY S4 Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
