Question about Sys Audio Players & Recorders
I thing that any one of speaker is disconnect then hole sys is totally off is it right
  • Sys Master
  • 3,960 Answers
It depends upon the specific speaker system your are using. If the speakers are connected, where one slaves off the other, and the master is disconnected then the entire system will be down. If the slave is disconnected from the master, then only the master will work. Take a look at the computer speaker manual, or download it from the Internet.
Posted on Apr 18, 2015
Kenwood KRV6030 Home Receiver - Dolby Surround - 1991/NO AUDIO FROM RIGHT SPEAKERS and SURROUND NOT FUNCTIONING CORRECTLY/ STANDBY IS ALWAYS ON/ALSO I'VE NEVER HAD A REMOTE CONTROL FOR IT
So, if standby is always ON, do you get ANY sound? Or was the right speaker symptom a precursor to the total outage? There might be a clue there.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
The remote is available on eBay...
http://cgi.ebay.com/Kenwood-Remote-RC6030-KRV6030-/370485539582?pt=LH_DefaultDomain_0&hash=item5642a8b2fe
May 04, 2011 | Kenwood Audio Players & Recorders
How do I connect speakers
to connect speakers: You look at the back of your computer, there will be several small holes, most are color coded. the green hole is the output for speakers.
there is usually also a small arrow pointing away from the hole, this is the icon for OUTPUT. Other holes will have an icon for INPUT and for microphones.
If you have trouble seeing these things, you can just plug your speakers into the first hole. Goto YouTube and play a video, If you hear sound you have the right output. If no sound, try the speakers in the next hole. Continue until you hear the sound. ( this will not hurt the computer or the speakers )
NOTE: make sure the volume is turned UP on the speakers and the volume is turned UP on the computer.
Sep 30, 2010 | Acer Computers & Internet
Does not output to the right speakers. Cuts on and off. Connections are fine. Speakers are fine.
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RECEIVER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION, THEN THE RECEIVER WILL NEED TO BE SERVICED, AS YOU HAVE TOTALLY SIMULATED A BENCHED CONDITION THAT IS TOTALLY INDEPENDENT OF YOUR INSTALLATION. MOST TIMES, THE RECEIVE WILL GO INTO PROTECTION WHEN IT SEES AN EXCESSIVE LOAD WHEN TURNING UP THE VOLUME, WHICH IS USUALLY CAUSED BY TOO MANY SPEAKERS OR DAMAGED SPEAKERS, BUT IF NO SPEAKERS CONNECTED, THEN IT IS USUALLY BECAUSE THE RECEIVER SEES AN EXCESSIVE LOAD DUE TO ITS OUTPUT SECTION BEING DAMAGED. IN ANY CASE, ONCE REPAIRED, YOU MUST CHECK YOUR SPEAKERS FOR BURNED VOICE-COILS, WHICH WILL IMPOSE AN EXCESSIVE LOAD TO THE AMPLIFIER AND CAN CAUSE IT TO FAIL AGAIN. ONE SCENARIO HERE, IS THAT YOUR RIGHT SPEAKER IS SHORTED, THEREBY MAKING THE RECEIVER GO N AND OUT OF PROTECTION AND THE CONDITION OF THE LEFT SPEAKER IS UNKNOWN. THE OTHER POSSIBILITY IS THAT THE RIGHT SPEAKER HAS FINISHED BURNING UP AND IS OPEN, LIKE IT IS NOT EVEN CONNECTED AND THE LEFT SPEAKER IS IN THE PROCESS OF BLOWING AND IS THE ONE PUTTING IT IN AND OUT OF PROTECTION. AT ANY RATE, YOU REALLY NEED TO VERIFY THAT THE SPEAKERS VOICE-COILS ARE OK. I KNOW YOU SAID THEY WERE FINE, BUT YOU NEED TO REALLY CHECK THEM CLOSELY. YOU CAN USE AN OHM-METER TO CHECK ONE SPEAKER AGAINST THE OTHER FOR COMPARISON. WHILE NOT TOTALLY ACCURATE, IT WILL BE CLOSE ENOUGH TO DETERMINE IF THE VOICE-COILS ARE DAMAGED, SHORTED OR OPEN. AN 8 OHM SPEAKER WILL SOMETIMES READ A LITTLE LOWER THAN 8 OHMS, USUALLY AROUND 7 OR SO, BUT NOT LESS THAN 6. ALSO, DO CHECK THE SPEAKER WIRES THEMSELVES FOR BEING SHORTED OR PINCHED SOMEWHERE. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 14, 2010 | Yamaha RX-V795 Receiver
Have an onkyo txsr501 w/jbl scs135 surround sound sys, i disconnected it to paint room and when I hooked it back up the sub worked for about 15 mins than stopped went to standby, if i turn off the sub and...
If there is a way to cut and resplice the speaker wires at both the receiver and the speaker connections, try that. A good clean cut with no hanging copper wires is key.
Nov 25, 2009 | Onkyo TX-SR501 Receiver
My sound not work
when you connect your speaker with pc then keep in mind that you are pluging the right cable in right place.
Mar 10, 2009 | Sys 4.1 pc. 140 Watt Speaker Computer...
I lost sound on one side of bose stereo system., Seems its the power ouput on the right side speaker, i changed speakers and the right one works when plugged into the left output. How do I open the bose...
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
Jan 04, 2009 | Bose Acoustimass 15 System
Remote code SAMSUNG
I have a samsung HT-AS720S surround system it is 21 months old. the right speaker has popping and static coming from it, had to disconnect it. Moved wire to another speaker-same thing. Contacted samsung tech to help, went through a number of test they said I have to send it in for repair. Warranty is only one year.
I also have a problem with the sound when watching tv it goes from normal to very quit, it's irritating-no matter how high I turn it up the base goes up but volume stays down. On shows that are on DVR all sound is good. Watching a DVD is also good.
Please help
Nov 05, 2008 | Audio Players & Recorders
No sound
u have to plug the speaker in green hole only.
Sep 02, 2008 | HP JBL Platinum Computer Speakers
Kenwood Car stereo receiver
Sounds like the woofer cones are blown, no fix for that except to replace them.
You did the right thing disconnecting one at a time. Are both speakers doing that? It is a little strange that both would go out at the same time, but stranger things have happened.
If you have an extra speaker laying around someplace that you know is good (even a home stereo speaker), try disconnecting both speakers and connect the one good one to see if it sounds OK. If it sounds good or at least normal, you have some bad speakers. If the one speaker still sounds bad, you have a problem with the speaker wiring someplace. You might even need to run new wires just to rule them out as a problem.
If the problem is not the speakers, then this is a very strange problem indeed!
Good luck and I hope this helps you. If you need more help just reply back after you checked them out a little more.
Jun 18, 2008 | Car Audio & Video
51 people viewed this question
Top Sys Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sys Audio Player and Recorder Expert? Answer questions, earn points and help others
