Question about Garden
How do I lubricate the rear axle?
Where is the oil fill plug?
justuscc
  • 360 Answers
SOURCE: how do i oil the rear axle
its on the side of the housing. a 3/8 rachet fits in it good luck.........jimmy
Posted on Sep 26, 2008
STEVIE_N_24
  • 147 Answers
SOURCE: Changing rear axle lub
About 2.5 qts remove fill plug in cover or plug may be located on pinion housing. Fill until fluid starts to run back out.
Posted on Mar 29, 2009
SOURCE: where is the fill plug for the rear axle? i dont
Yes. Drain plug is in bottom, fill plug would be about half way up the differential housing. Probably the same type plug for both.
Posted on May 06, 2009
emissionwiz
  • 78919 Answers
SOURCE: where is the drain plug and fill hole located for
it is just one plug, it is locted on the side of nose of the differential, it is pipe plug
Posted on Mar 12, 2010
  • 11 Answers
SOURCE: I AM REPAIRING A SNAPPER COMET 30 B/S 7HP RIDING
Chances are you wont get a manual, just lube it up.tires probably 12 to 15 lbs .the belt is mecanicly tensioned so there is no adjustment. Check the idler pully tensoner and ingage lever for proper travel and tention
Posted on Jun 20, 2011
Needto lubricate rear wheel bearings on a huffy single speed bike
as most bikes do not have seals on the wheel axles , it is possible to lay the bike on the side , use machine oil on the hub and axle area and spin the wheel while allowing drops of oil onto the axle bearing hub area
or you can take the hub apart and fill with a very light grease
Jul 23, 2015 | Huffy Cycling
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
I want to Greese the rear tines! there is no oil or greese screw to fill or drain whats the deal
On a troy built rear tines are lubricated by the transmission oil. You will find a pipe plug usually 1/8 in with square head on the side of trans. near wheel axle.
Mar 22, 2011 | Troy-Bilt Garden
Need to find out how to add oil or check the oil in the rear end of a 2000 GMC gimmy
Hello, there is a fill pluf on the passenger side of rear end to check the fluid level and to add fluid. here is some help on this.
  • Remove the rear axle fill plug.
  • Inspect the lubricant level. Specification
    The lubricant level should be between 0-10 mm (0-0.4 in) below the fill plug opening.
  • If the level is low, add lubricant until the level is even with the bottom edge of the fill plug opening
    Sep 20, 2010 | GMC Jimmy Cars & Trucks
    How do you add transmission fluid to a 2000 town country
    The tranny fluid is added through the tranny dipstick (make sure it's not the oil dipstick). Fluid color should be red and the dipstick should have instructions on how to check level (car in park, engine at idle). Funnels are your friend here.
    Jul 26, 2010 | 2000 Chrysler Town & Country
    97 s10 blazer.. need to fill rear with gear oil. where is plug?
    most axles fill plugs are located on the rear cover just fill until it starts coming out and your done. on some axles there will be a plug on the axle itself located on the fron side of the housing close to the driveline
    Mar 05, 2010 | 1997 Chevrolet Blazer
    How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
    Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
    Removal
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
    1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
    1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
    1. Drain rear axle lubricant by removing the axle housing cover .
    1. Remove differential pinion shaft lock pin and differential pinion shaft .
    1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
    1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
    Installation
    NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
    1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
    1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
    1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
      NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
      sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
    1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
    1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
    1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
    1. Install rear disc brake caliper and rear disc brake rotor .
    1. Install wheels and tires.
    1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
      Rear Disc Brake Caliper Anchor Plate
    1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
    1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
      sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
    1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
    1. Install axle shafts as outlined.
    May 13, 2009 | 2004 Ford Crown Victoria
    Rear wheel bearing
    SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
    1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
    1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
    1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
    1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
    1. Remove the differential pinion shaft (4211).
      1. Remove the differential pinion shaft lock bolt (4241).
    1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
      Remove the U-washer (4N237).
      1. Push the axle shafts (4234) inboard.
      1. Remove the U-washer.
    1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
      Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
    1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
      Remove the axle shaft.
    Rear Wheel Bearing and Axle Shaft Oil Seal Removal
    1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
    1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
      Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
    Installation
    1. Lubricate the new rear wheel bearing with the specified lubricant.
    1. Using the special tools, install the new rear wheel bearing.
    1. Lubricate the lip of the new wheel bearing oil seal.
    1. Using the special tools, install the new wheel bearing oil seal.
    1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
    Installation
    1. Lubricate the lip of the wheel bearing oil seal
      Install the U-washer.
      1. Position the two U-washers on the button end of the axle shaft.
      1. Pull the axle shaft outward.
    1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
      1. Align the hole in the differential pinion shaft with the case lock bolt hole.
      1. Install a new differential pinion shaft lock bolt.
    1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
    1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
    1. Install the rear brakes. For additional information, refer to Section 206-04 .
    1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
    1. Lower the vehicle.
    Apr 10, 2009 | 2004 Ford GT
    Mar 29, 2009 | 1999 Chevrolet C1500
    Replace left rear axle seal 1999 ford explorer
    Axle Shaft Removal
    1. Remove the differential housing cover (4033).
      1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
      1. Remove the bolts.
      1. Remove the differential housing cover.
    1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
    2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
    3. Remove the U-washer (4N237).
    4. Push the axle shaft inboard.
    5. Remove the U-washer.
    2. Install the differential pinion shaft lock bolt finger-tight.
    3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
    Seal Removal
    1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
    1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
      NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
      Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
    6c7eb46.gif Installation
      • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
      • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
    1. Using the special tools, install the rear wheel bearing.
    1. Using the special tools, install the wheel bearing oil seal.
    Feb 22, 2009 | 1999 Isuzu Rodeo
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
