Does this TV have audio out connectors? - Televison & Video
  • 3,957 Answers
Please provide the manufacturer make and model. You can also consult the manual, which will tell you what inputs and outputs are available on your unit. If you are missing your manual, just Google search for the manufacturer make, model and the word manual. There is no way we can assist you without knowing about the specific make and model you are referring to.
Posted on Apr 18, 2015
How do I connect a Pioneer S508 amplifier to a Samsung Bluray DVD player?
This is a common problem. Not all models of DVD players have analog audio connections.
The image of the back of the DVD is suppose to be a BD5700?
The connections AUX on the amp and the connections audio out red and white RCA connector are connected with a audio cable.
The images marked with the red are these locations
If your model of DVD player does not have a set of red/white audio connectors you have two other choices.
  1. If TV is connected via HDMI that the audio is included to the TV. The TV will likely have a set of red/white audio "out" RCA connectors that would connect into the Pioneer.
  2. Purchase a specific powered adapter that takes the Optical audio signal and converts to a analog RED/White RCA connector that will connect via audio cables into the AUX of the Pioneer,
Dynex Optical Coaxial Digital Audio to Analog Audio Converter Black
Jan 07, 2016 | Samsung BDD5700 BluRay Player
I have a WahlDorf sound system no instructions...its WD310HT Home Theater.its a subwoffer an 5 speakers how to connect to TV or DVD?
there is no info for a 310,but,there is for a 305,you need to make some cables for it,you need some rca cables with one end cut off,the rca plugs into the tv audio output,the two wires from each one,go into the push connectors,treat the outside wire as neg(black) and inside wire is always pos(red),,the top 2 push posts on the left are for the left audio from your tv,the 2 posts on the right are for the right tv audio,there are 4 more connectors for another device,like a dvd etc,push connectors operate by pushing in on them and pushing the bare wire into the little hole and releasing,
25715906-ghuqylfbvqx2ddmcce1obb43-5-0.jpg this is the only pic available,the 4 push connectors on the right are,tv right,pos,,tv right neg,then other audio right neg.,,the bottom one is other audio pos,,,,the 4 on the left side are left tv audio pos,,then left tv audio neg,then other audio left nrg,,then left other audio pos,,,
25715906-ghuqylfbvqx2ddmcce1obb43-5-2.jpg this is like what you need,the red is positive and bare is neg
May 27, 2015 | home Audio Players & Recorders
How do I connect my pc to the smart share tv?
Hi Roxy
The first thing to do is determine what the TV input connectors are. Then what the computer output connector type is.
Write these down and then you can go into an electronics or cable supplier company and ask the staff.
Computers often use a Super VGA output connector that carries video only. The sound comes either out of an Audio out connector or fibber optic Toslink connector. Would be excellent if it had a HDMI connector caring audio & video. Check your computer manual.
The best input connector to use on a modern TV is HDMI. This is a single connector carrying video (1080) and audio. then you would simply connect one to the other.
There are several converter boxes available from xxxx to HDMI.
Good Luck
Trevor
Aug 17, 2014 | HP Computers & Internet
How to connect 520 to a tv
In the Quick Reference Guide ()
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d520_setup%20guide_en-us.pdf, at page 12, you can see 2 connectors that can be used to connect your laptop to the TV (4=S-Video TV-out connector and 6=video connector).
Depending of your TV (type and model), you can use one or both of theese connectors. For an analog TV you can use only the S-Video TV-out connector, using a proper cable (S-Video to S-Video or S-Video to SCART). For a digital TV (LCD, LED) you can use also the video connector (D-Sub 15 pin), if your TV is equiped with a similar video connector. If not, you must use a converter, but is more expensive.
In all cases you must use a second cable for the audio signal (see the audio connectors, at page 11).
Aug 09, 2014 | Dell Latitude D520 Notebook
HOW DO YOU CONNECT TO THE TV
You look for the video and audio outputs available from your camera, the standard analog type are video composite (yellow RCA connector) and audio L channel (white RCA connector), R channel (red RCA connector), if the audio output is mono, you should have a black RCA connector, the you should look the corresponding inputs at your TV set and select them. If you have a digital output, usually a firewire connection, you should look for the cable and corresponding input at your TV set.
Feb 08, 2011 | Mitsuba HDC-505 Camcorder
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
I'm trying to connect my denon dvd player to tv
The yellow plug is composite video; the red and white are analog audio. Not knowing specifics about your TV or Denon model number, I would suggest:
-- the red and white connectors go to the audio in on the DVD, and to the audio out on the TV. There will be a left channel and a right channel. Make sure you connect the same color plug on the same channel. In other words, if you put the red plug in the right audio out on the TV, also put the red plug in the right audio in on the DVD, the white in the left audio out on the TV and in on the audio in on the DVD.
-- the yellow connector will go on the video out on the TV, video in on the DVD.
For better audio, consider using gold connectors, if you don't already have same.
Alternatively, you may wish to purchase and use an S-video connector if your equipment allows. This would replace the yellow composite video cable, and enhances your image.
Hope this helps!
May 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
How do you get to s-video on a durabrand tv, av button just goes from tv, to aux one (rca in back) to aux two (rca in front) then back to tv again?
Check to make sure that your series of set has an S-Video connector on the input panel (usualy located on the rear side of the set).
In most TV sets, the S-Video is shared with video input 1, and or 2.
For example, if the S-Video connector is located at position 1, then make sure that there are no other connectors in the video connector for the base-band video feed. The audio connectors will be okay, because S-Video does not carry the audio.
When using S-Video, the L and R audio, and the S-Connector video input will be used on the respective video input.
Jerry G.
Oct 02, 2008 | Televison & Video
I have no sound from my samsung tv to Samsung HT-TZ315R/XEU i have connected with hdmi and the white and red plugs i have sound from the dvd player but not the tv any suggestions
Make sure the red & white connectors you are using on the TV are actually audio out, and not audio in. If you are using the connectors on the side of the tv (adjacent to the yellow connector), then these are inputs.
If your TV has no audio out connectors, then if you have a European TV, you can use one of the scart connectors with an adaptor.
Also, check the red & white connectors you are using on the home theatre system are inputs. Also check the source is set correctly.
May 16, 2008 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
