Question about John Deere Garden
I have a JD318 it was running great the other night , but now it wont start. I think it is stuck in gear. How do I get it into neutral manually?
    Top Expert:
  • John Deere Master
  • 10,875 Answers
Your neutral safety switch wont let it start,if you want to bypass the safety switches,pull the small black wire off the coil
Posted on May 09, 2015
3 Suggested Answers
  • 22 Answers
SOURCE: craftsman lt1000 rider 42 in deck is stuck in gear
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Posted on Sep 19, 2009
  • 6468 Answers
SOURCE: my craftsman re2000 starts but wont move...seems like it is stuck int neutral
check the belt tension then check . then check the rod on the rear of the mower to see if the rod you pull when you want to push it is not released
Posted on Apr 19, 2012
1984 BMW 533I MANUAL 5 SPEED
If you tow your car in neutral how come is stuck on one gear. Towing got no problems. That mean it wasnt in neutral it was in gear but the clutch is stuck and seem the gear is in neutral. You should have clutch problem before you think about gear box.
Jul 21, 2013 | Cars & Trucks
MY TRUCK IS stuck in neutral and wont go in any gear
Now you will need a repair shop
Better to forget the guys & find something else
Mar 06, 2013 | Cars & Trucks
Bike will start in neutral but is not rolling something in the rear is locked
ok- you've got an old honda dual mode transmission. It will start in neutral and will run in gear but you can't transition from neutral to gear-clutch issue,I think its a hydraulic clutch may require slave cylinder or rebuild-first check for clutch plate movement b4 rebuilding-clymers/haynes manual great investment. Next the battery: either the battery is pooched- can't hold charge or the stator/regulator is malfunctioning or has failed and your battery is the only thing powering the bike thus it runs until the battery has been used up, good luck.
Nov 09, 2012 | Motorcycles
I have a 2001 Saab 9 3 se automatic transmission it drives great but wont go into park and I have to start it in neutral.
sounds like a linkage problem. when in gear, does the shift indicator look like its in-between gears?
Sep 23, 2012 | 2001 Saab 9-3
Crank but won't start, only starts in neutral
newer veicles wont start in gear i think its for saftey reasons but i have a 2005 truck that does the same thing
Jun 05, 2012 | 2005 Honda Accord 2.4
2001 YAMAHA ROADSTAR will only start if kickstand is UP not DOWN and clutch handle pulled in for some reason it thinks bike is in gear but it is not. The neutral light is on bike drives good and shifts...
Hi, Layton_dille the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Re only start neutral dilemma Road Star Forum Yamaha Road Star
neutral light wont come on when in neutral and wont start with kick stand...
Yamaha XV1700PCRC Service Manual
OEM parts for Yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
May 07, 2012 | Yamaha Road Star Motorcycles
My gear shift is stuck in park. The car starts up fine, but shifter wont budge.
the fuse is bad for shift lock solenoid. Read owner manual section on brak-shift interlock. Check fuse for nbrake lights. Brake lights work.
Owner manual has emergency by pass procedure. I think you turn key to OFF and then shift to neutral and start car then. Next time in park, you have to repeat.
Oct 29, 2011 | 2005 Lincoln Aviator
03,YZ250- Wont select gears stuck in neutral shifts to 1st(i think) sometimes
Hi, Www_105eya for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZ80 Tranny Stuck in Neutral Yamaha 2 Stroke
Bike won shift stuck in one of the upper gears
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 16, 2011 | 2003 Yamaha YZ 250
Truck starts but won't engage in any gears
if you can move it into gear when its not running, id say clutch,
but if it wont go in at all, then Im thinking shift forks or linkage
May 25, 2009 | 1998 Dodge Dakota
Garden Logo
156 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
