We are snowbirds in fl and last week when we unplugged computer & printer to move back home, now the printer does not connect
  • Brett Duxbury
    Brett Duxbury Apr 18, 2015
    Hi Anne DeMayo, we want to help you with your question, but we need more information from you. Can you please add details in the comment box like how does printer connect is it USB or ethernet cable what model number and make ?
    Top Expert:
  • 2,044 Answers
You will need to go into Configuration. I am assuming you are referring to a Wireless Printer. If this is True, you are now on a DIFFERENT NETWORK and it needs to be configured for that Network.
If this is a Cable Connected Printer, I would recommend that you Delete the Printer on your Control Panel / Printers and then while it is plugged in, let it RE_LEARN or find it again and the problem will be resolved..
Posted on Apr 18, 2015
Ge potscrubber dishwasher #2230
try removing the bottom panel with washer off look for small fan on motor turn to make sure it is turning free. This happens a lot with the snowbirds in Fl. Simple fix.
May 15, 2014 | Dishwashers
Epson wf-7520 power light, auto answer light & wi-fi light blink
As far as the wifi is concerned, try getting it connected to your home network. Once it gets connected, go into your network settings and try to get the IP address. If you can obtain that, you should be able to add a network printer using TCP/IP port. Also, see if you can factory reset the printer, and start the setup all over.
Feb 17, 2014 | Epson WorkForce WF-7520 Wide Format...
I purchased a DYNEX USB 2.0 Port Hub last week. I have 2 computers and want to have both of them hooked up to the same printer. I purchased 2 A >A USB cables and the printer is still not working. I...
in either computer have you set the printer to default so that each computer knows where to send the data
you may also have to have the computers on a home network for it to work
the hub by itself is not the answer
Jun 03, 2017 | Dynex 4-Port USB 2.0 Hub
I have had this printer for several years, and never had any problems. the last i used it worked was last week. then out of nowhere, my computer says i dont have a printer hooked up to my computer. i have...
You could try the following:
Do a shut down of your computer.
After the computer shut down, unplug your printer usb cable.
Turn your printer off then on and leave printer on.
Restart your computer and wait until computer has fully started up.
Plug in the printer usb cable.
The computer should detect the printer.
Dec 31, 2010 | Office Equipment & Supplies
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
Printer not working
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Mar 02, 2009 | HP Color LaserJet 2600n Printer
The bottom of the screen has become darker!
Hi
The symptom you are telling is similar to FL inverter problem but with that case usually entire screen goes dim. You may try to reset the settings (Usually AUTO button). Unplug and plug in the electrical connection+Computer connection. Also make sure your Display setting in computer side has not been modified. If issue persist take to the qualified service center. FL inverter is the illuminator part of LCD works like fluorescent tube. FL inverter issue rather lower cost compare to other LCD issues.
Good Luck Happy New Year
Dec 28, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
46 people viewed this question
k24674
