Question about Huawei Cell Phones
How to fix my Huawei touch screen phone it is slow and unresponsive at times.
SOURCE: Unresponsive touch Lg Dare Touch screen
sometimes you just need to take the battery out and put it back in. If you've already done that then you may need to take it to Verizon and get it updated.
Posted on Jul 09, 2009
imtoobubbly
  • 6 Answers
SOURCE: Instinct phone with screen completely unresponsive to touch.
if its been water damaged or anything like that to where the screen is even cracked or scratched touch phones are very sensitive and yes it might need to be replaced.
Posted on Jun 21, 2010
n00h
  • 624 Answers
SOURCE: Unresponsive/slow satio.
Hello and Welcome to FixYa!
Yes sure, you should try to upgrade your firmware before spending any money, its easy as 123, all you need is the Data Cable (That comes with a new piece) and an active internet connection.
If you have them, just visit the link I've provided below, there you will get all required information/guides and the Download Utility. After downloading and installing, run it and the wizard will guide you on how and when to connect your phone, I'm sure that your issue will be resolved because it seems like a firmware malfunctioning. Its worth a try. Try it and do share the experience.
If you are having trouble/questions, do ask me, We are here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Satio Firmware Upgrade
Posted on Jul 29, 2010
  • 30 Answers
SOURCE: my phone's touch screen is
A diagnostic list includes 1. performing a full device power charge 2. change the entire battery 3. Reset the device with the pin area provided to estblish default settings 4. refer to the user manual 5. contact technical support online for further asistance
Posted on Dec 05, 2010
  • 1040 Answers
SOURCE: when i try to even
DNS stands for Domain Name Service. Most DNS errors usually indicate lack of a connection to the internet. DNS is used to translate human addresses (for example, www.bhcblog.com) into computer addresses (like 10.64.254.11) ..
This error occurs due to fault in network, Therefore contact your network operator and ask them to solve the problem. Alternatively you can re-install or recreate the internet profile manually with IP address and DNS server address... for this also you should contact your network operator and ask them to provide you the IP and DNS Server address...
Hope this has helped you.. THanks
Posted on Jan 05, 2011
Ascend y330. Where can I get free SIM unlock code?
http://sim-unlock.net/simlock/Huawei/Y330
How to unlock Huawei Y330 by code?
Unlocking Huawei Y330 by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock Huawei Y330. You need to provide IMEI number of your Huawei. Type on keyboard *#06# or remove battery from your Huawei Y330 to check IMEI number.
To unlock Huawei phones you need to provide them with IMEI number and model of your phone.
Huawei Unlocking process is safe and easy.
Nov 21, 2015 | Huawei Cell Phones
Huawei problem
phone is huawei ascend g510.very slow and unresponsive sometimes.
May 29, 2014 | Huawei ASCEND G510-0251 Unlocked GSM...
Touch Screen doesn't work
I HAVE PROBLEM WITH MY SAMSUNG E2232 PHONE PLS I NEED HELP
Feb 05, 2014 | Huawei Ascend Ii M865 Muve White Cell...
My phone has a black screen and a green robot on it when i turn it on
That is the boot up screen for the android. You can change the back ground in the settings menu under personalize I believe it is.
Jan 21, 2013 | ZTE Warp
Pls i need the SIM network unlock code for Huawei U 8650-1 from Tigo tanzania, IMEI: 862076012040587
pls i need unlock code for huawei u8650-1 from tigo TANZANIA imei 862076012040678
Oct 05, 2012 | Huawei Cell Phones
My samsung sch-r710 touch screen is unresponsive. Will a hard reset fix the problem? How do I perform a hard reset?
try to calibrate the touch sensitivity setting before you reset it this always work in any case.nno need to to do a hard reset
Aug 14, 2012 | Samsung Lands Phones
My Huawei U7510 touch screen does not work
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Take care
Jun 12, 2011 | Cell Phones
Screen touch not working
Hello
Clean the touch screen on the phone with an electronics cleaning cloth or wipe. Dirt, dust and oils from your fingertips can collect on the screen, making it unresponsive or desensitized to your finger's touch. Clean the screen in a circular motion.
Eliminate any bubbles under the screen protector. You can do this by removing the screen protector and then reapplying it, going from the top of the screen to the bottom or vice versa.
Remove the screen protector and do not place the protector back on the touch screen. Screen protectors are made for protecting a touch screen, but sometimes the protectors make the touch screen less responsive to your finger touch or even altogether unresponsive.
Power off the touch screen phone if the touch screen stops working when a new program is opened. This isn't a problem with the touch screen, but a problem with the software trying to load or open on the phone. Some programs can slow response time with the touch screen or may not respond to it at all.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Samsung Star GT-S5233 Cell Phone
May 26, 2010 | Samsung Instinct Cell Phone
Cell Phones Logo
29 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
rostit
William Alequin
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
