Question about Exercise & Fitness
Can anyone please tell me how to replace the battery on a Vivotion R1000 rowing machine?
Do I need to remove all of the outer casing or is there a way of lifting out the computer console to get to the battery? Thank you.
  • 4 Answers
SOURCE: Replacing ignition switch on Saab 1996 900s 2.3 I 5 speed
You take all the center console and plastic ducts from between the seats. There are 4 10mm bolts holding the shifter mechanism to the floor. Take these off and do your best to flip the whole housing to where you can access the bottom side. The ignition switch is attached under there. As I recall there are 2 T20 screws holding it on.
Posted on Nov 07, 2008
  • 566 Answers
SOURCE: how do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Posted on Feb 26, 2009
  • 4 Answers
SOURCE: 2005 Lincoln Aviator. Replace busted speaker third row seat??
the sub panal doesnt come off seperate you will break it if you try and you will need to remove the whole side panal its e-z afer the panals removed good luck and remember dont force or pull to hard
Posted on May 07, 2009
kingrh
  • 14 Answers
SOURCE: How to remove outer case on Pl926wbi
Remove the four bezel screws on the bottom edge of the monitor. Gently pry up where you removed the screws and slide the bezel off towards the top of the monitor. The six mounting screws for the lcd panel will be visible. Remove them and inplug the lcd cables and set it aside. You now have access to the main circuits.
Posted on May 21, 2009
  • 193 Answers
SOURCE: replace outer screen on a i68
http://www.mysciphoneshop.com/touchscreen-replacement-to-suit-sciphone-p-15.html?zenid=68qqnj2u74qa795hlddrjenos0
myschiphoneshop.com
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Posted on Jun 25, 2009
Hotpoint wmf560 aquarius washing machine
BIG JOB !!! The whole machine has to be stripped down. Ie/ The complete bowl assy has to be removed from the machine, the outer bowl separated from the inner bowl, the main seal removed, and the bearings pressed or knocked out of the housing in the rear of the outer tub. If the bearings have failed , it would be almost certain that the drum shaft has worn and or been damaged. You will need a set of bearings, drum spider shaft assy, and main seal. If its an older machine, it may not be worth it.
Apr 13, 2015 | Washing Machines
How do i operate control panel on vivotion cross trainer?
Read your owner manual. download from www.fitness.manualsonline.com and execute it
God bless you
Oct 16, 2013 | Exercise & Fitness
Can you tell me where the brushes are located in a Hotpoint First Edition WMA 20 please
Removed lower rear panel of washer.
Undo 2 screws securing motor to outer drum casing, unplug motor lead and remove motor, brushes ar e located at the end of the motor furthest away from the motor pulley.
Aug 06, 2010 | Hotpoint First Edition WMA20 Front Load...
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
I need to replace batts in a Braun #5520...i donr
You will need to remove the two screw covers on the bottom of the shaver. They are on each side of the hole where the cord plugs in. Then remove the two screws to take off the bottom and you can then slide the outer case off the bottom also. You may need to change the position of the lock to get this outer case off.
You will then need to remove the black plastic back of the inner case. It snaps on so you will need to 'unsnap' it. You can then remove the circuit board for easier access to the batteries. Reassemble in reverse.
You can purchase batteries from shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
be sure to read the installation note on the item page
Feb 09, 2010 | Braun Flex Integral Shaver 5520
Hotpoint WMA48P bearing replacement
REMOVE THE POWER PLUG FROM THE SOCKET
this is a messy job, you will need to remove the lid remove the front of the machine 2 -3 screws behind the clip on pannel front bottom I cant rember if the front hangs on two lugs one either side or if there are acouple of screws behind the faceplate, you will need to disconnect the door safty switch (make note of the wire positions), remove the wire band that clamps the door seal to the outer drum, now you should be able to see the drum and the drum outer casing, you will neeed to remove the access panel from the rear of the machine and if the belt has not already come off remove it , you notice a large nut holding the flywheel on inspect closely as there may be some securing tags (large washer with folded edges stopping the nut from comming undone ) remove nut , you will now need to remove the drum from the front of the machine using a peice of wood place on shaft and strike it with a heavy hammer or a mallet do not worry about damaging the shaft as you will need to replace this as well as the bearings as when bearings fail it is normaly to do with water getting to the bearing and corroding them (rust) untill they give up this normally damages the shaft, once the shaft is removed if you look through to shaft hole you will see the outer casing of the beaings thease need to be removed normally by tapping out (not always easy)there are two one at fromt one at back the back one is removed from inside the drum front removed from rear of machine , once this is all clear you are ready to the reverse putting it all together, the bearing kit should contain all you need to replace the bearings including the spider ( the three legged fitting that connects to the drum and has the shaft on it) when replacing the bearings make sure that where the old bearings come out of is nice and clean (fine sanpaper to remove small high spots) i use vaselene to aid bearing seating , using a rubber mallet genlely tap the edge of the bearing into place (never hit the center of the bearing as you could damage the seal and or the bearing) when the bearings are in smear some grease onto the shaft and rfit, a bearing kit trade is about 20 uk pounds
Jan 15, 2010 | Washing Machines
Whirlpool washing machine clutch replacement
Hi
Thanks for using FixYa. For servicing the clutch you’ll need to first remove the gear case. The gear case can be removed by first removing the outer cabinet. After removing the cabinet, remove the pump and motor assembly. Now carefully lay down the washer on its back and remove the 3 bolts securing the gear case. Now pull the gear case straight out from the tube support assembly. Now, compress the clutch spring with a pair of pliers and lift the lining from the clutch hub. To remove entire clutch assembly begin by removing the spin tube thrust washer up & off the agitator and then remove the tube support ring. Remove the retainer ring and lift the clutch hub up and off spin pinion.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 25, 2009 | Whirlpool Washing Machines
How to remove hot water inlet valve
In ost cases there is a scerw on the outide of the machine which holds the bracket that holds the valve. Go ahead and get the valve and look over the new one, it will tell you volumes about how to install it. Like where that screw would be, Good Luck!
Mar 12, 2009 | Hotpoint First Edition WMA20 Front Load...
DJ Ditty Battery?
Battery is not replaceable on this unit. Removing the outer casing will just cause components to fall out - you will end up destroying the player.
Oct 30, 2007 | Dell DJ Ditty MP3 Player
Exercise & Fitness Logo
431 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
