Question about Building Materials
Where can i get a remote control for a wall mounted eletric blyss carolina model LDBL2000A DD5R
drumbanger
  • 1199 Answers
SOURCE: neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Posted on Dec 06, 2008
  • 3197 Answers
SOURCE: My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
Posted on Aug 03, 2009
  • 3197 Answers
SOURCE: How do you clear and re-enter a new code for wall mounted remote
To change the code you need to locate the smart/learn button which is near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you like and press enter.
See if this works for your car.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxillary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Posted on Feb 02, 2010
  • 59 Answers
SOURCE: I have a Sears Model
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Posted on Apr 03, 2011
  • 3197 Answers
SOURCE: My lift master wall mounted control is blinking
Locate the lock button on the wall control. Press and hold this for 3 seconds. The blinking of the light should stop and your remotes will once again work.
Posted on Oct 15, 2011
Hi I need some help my blyss carolina electric fire is not switching on. I've tried a new fuse in plug and I think remote control is working (remote has red light on when button pressed) help please
A red light On; and you things that the remote is perfect. it is not right. It is only an indication, that the batteries are installed properly. You should check it for its infrared emission. Infrared emission emits from its front window is invisible to human eye.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jul 04, 2016 | Televison & Video
Bylss 34hfu600grt electric fire. Where can I get instructions?
[PDF]LDBL2000A-DD5R EN - Free Instruction Manuals
www.free-instruction-manuals.com/pdf/pa_843360.pdf
CAUTION - Fire, electric shock, physical injury and material damage hazards: To use the appliance, always follow the instructions for and assembly, use ...
BLYSS 34HFU600GRT KURZ User's guide, Instructions ...
www.manualspoint.com/results.php?...BLYSS%2034HFU600GRT%20K...
User's guide, Instructions manual & Installation guide - Immediate download or search mode services.
Jan 07, 2016 | Home
Where can I get a replacement remote control for my blyss siena wall hung fire
Try this:
http://www.fixya.com/support/t20242258-buy_replacement_remote_control
and other sources like ebay, and Amazon. If not the MFG customer service email.
Jun 07, 2015 | Building Materials
Remote control for blyss carolina wall hung fire ?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Aug 15, 2014 | Televison & Video
Blyss
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Mar 24, 2014 | Televison & Video
Where can i get a a replacement remote for a Blyss Carolina wall hung remote control fire?
Hi can I ask did you find one of these remotes? if so could you please tell me where as I am struggling to find one myself Thanks!
Sep 21, 2013 | Dryers
The hand held divice stopped working and the mounted pad light flashes quickly. The mounted pad does work.
The most likely problem here is that your wall control is bad. I would disconnect the 2 wires going to it and I think you will find your remote works. Replace the wall control.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
153 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
