Question about Sony Televison & Video
We are setting up the box & have the leads connected. Have got the remote to start & turn off but it will not do any other functions.
We have a Sony TV & have used a code & it will start the TV but nothing else
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
SOURCE: NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
Posted on May 30, 2009
  • 33 Answers
SOURCE: Comcast remote control won't turn on or off Sylvania LC321SS9 TV
Usually you need to make the remote search for the right code that will work with your TV. Google you Comcast remote model for instructions and it willl how you the right steps.
Posted on Jul 04, 2009
SOURCE: Converter box remote will not program
i have a admiral tv and i'm wanting to program my remote that goes to my converder box to the tv is there anyway i can do that?
Posted on Sep 13, 2009
How do you wire the remote switch on the sony xplod 52wx4?
If you mean the "remote turn on" lead, you should connect this to a 12 volt remote turn on lead from your head unit or you can wire it to a 12 volt source that turns on when the key is turned on to start the vehicle. Wiring it to a dedicated remote turn on lead from the head unit is optimal though.
Feb 09, 2012 | Clarion APX400.4M Car Audio Amplifier
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
Connecting a standard cable box to an HDTV and remote doesn't run cable box. After I connect my new HDTV to my standard(non HD) cable box if I use my remote to do a channel up or down it just starts...
are you connecting by scart ? if so some hdtvs send signal backfeed/try aerial tv out to tv/also try basic scart lead as scarts can be faulty dont fit a pound shop one get a top one from maplins etc
Nov 10, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
How do you connect bt vision to a sony bravia kdl 37v4000.I have it working ok on freeview only but the bt vision appears on analogue channel 6 and the vision remote changes the tele channel not the vision...
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
Jul 23, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Surround sound to work with sky+
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Feb 20, 2009 | Sony DAV-S300 System
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Remote came w/coverter, no codes for Panasonic TV/DVD/VCR combo
Since you say the remote turns the box on and off properly, the control is probably working correctly. If you aren't seeing anything on the screen, you may not have the TV on the right channel (if you've connected it with an RF cable to the TV's antenna input jack). If you've connected the box using its video and audio outputs, you may not have selected the TV's video input.
As far as setting up the remote to work the converter box, that isn't necessary. If the remote is truly not working the box properly, and you have tried new batteries in the remote, you may have a bad remote or converter box and should take it back to the seller.
If the problem is setting up the boxes remote to work your TV, you may be out of luck. If you need to enter a brand code and your TV isn't listed, there is usually a code search function. The problem with universal remotes in general is that often they only give you control of a TV's basic functions but not advanced menu controls. The converter box remote may not be able to do more than just turn your TV on and off and control its volume. You may need to keep the original TV remote handy if you want to do things like adjust color levels, control closed captioning, or other functions like that.
Nov 25, 2008 | Insignia Digital-to-Analog Converter for...
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony Wega KV-32FS100
I had the same problem and found out that it wasn't making a good connection inside the the Directv box.The box was changed and that solved the problem.
Nov 16, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
