Question about GPX Tde1380b 13.3 Led Tv/dvd Combination
How can I fix the screen on the GPX model TDE1380B it goes black and takes a long time to clear up
Gpx cd karaoke player auxiliary goes in and out i think it's a shortage can it be fixed
Generally speaking, most electronics can be fixed. Your first step would be to spray the aux input jack with a small amount of electrical cleaner then insert and remove the plug a number of times. if that doesn't work, remove the knob on the Aux volume control and spray a small amount of cleaner down the shaft of the pot under the knob, then twist the shaft of the [pot a number of times. I use a cleaner called deOxit 5 and it works well. If cleaning these two areas doesn't clear up the problem, i'm afraid it will have to go to the shop.
GoodLuck!.
Jan 03, 2017 | GPX Music
Tip
Garmin Nuvi 1300 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1300 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1300 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Webupdate
on May 13, 2010 | GPS
It stoped powering up, won't come on.
Could be an open internal fuse or power supply failure
Apr 26, 2016 | GPX Tde1380b 13.3 Led Tv/dvd Combination
Source code for a gpx tv
My only suggestion is to look up GPX on some remote control code sites. I have not heard of GPX as a brand name but I bet it has a parent company that is more recognizable. Most remotes have an option to them to do a manual search which makes you go through all known codes to find it.
Oct 08, 2012 | GPX TDE1380B 13.3"" Led TV /Dvd...
I have a GPX DVD Model #D1816 player that shows a split screen that is in black and white.
Try disconnecting it from the power outlet for 5 minutes and then plugging it back in again.
May 02, 2011 | GPX D1816 DVD Player
On start up the TV produces a loud buzzing sound, the picture flashes then the screen goes black. What is the problem and is the unit worth fixing?
Major failure in the power source. If it's worth repairing only you know that - without actually seeing the tv i can  do just a very uncertain estimate of the price of the repair: around $150.
Jun 17, 2010 | GPX KCLD8886DT 8.1 in. Portable Television
Acer Lap Top - Screen Flicks Goes Black Then Comes Back On
looks like a videocard issue. try to hook a known good external monitor2_bing.gif. if prob persists, replace videocard.
Mar 30, 2010 | Acer Aspire 4930-6862 Laptop
Audio no picture
do you get a splash screen when there is no Disc playing ( something that says something like DVD VIDEO). If not and the scren is just always black then it sounds like the backlighting circuit has failed
Mar 17, 2010 | GPX PD808B Portable DVD Player with Screen
Have trouble keeping English language permanantly ON. All by itlelf changes to SUVAHILY or something like that timt and time again. How can I stop it ?
There are three levels of getting your Garmin 255W's attention andcorrecting bad habits (ie: not loading maps, or in your case, messing with the language settings). The second method (hardreset) is often enough to fix many problems.
Thefirst is 'soft reset'. There is a reset button along the bottom of yourgps. Push and hold it until it restarts. If you cannot locate yourreset button, sliding the power switch to OFF and holding for 8 secondsshould do the same thing.
The second method is a 'hard reset' or 'clear all user data'.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
The third method is a firmware upgrade via Garmin's Webupdater, or the myGarmin site.
Run through these fixes to get your Nuvi running as good as new.
I hope that helps.
Jan 02, 2010 | Garmin nuvi 255W GPS Receiver
GPX Tde1380b 13.3 Led Tv/dvd Combination Logo
166 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
