Question about Crock Pots & Slow Cookers
Is it true that once the slow cooker reaches boiling point on low it can not get any hotter or cook faster if you turn it up to high?
  • 484 Answers
I doubt this very much as they do not boil food. It will cook faster if you turn it up though.
Posted on Apr 18, 2015
How do you work the pc crock pot
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. Quoted from manuals on line
http://www.manualsonline.com/support/other/slow-cooker/manual-2538852
Sep 07, 2017 | Crock Pots & Slow Cookers
After the slow cooker boils is it better to turn it down to low
it is a slow cooker for the purpose of slow cooking so turn it to low and it will keep cooking
If you want fast cooking on high temp use a pot or a pan .it will be cheaper.
Apr 18, 2015 | Crock Pots & Slow Cookers
Should the lid have a steamer hole in it?
Slow cooking is done at below boiling point, so the lid doesn't require a steam hole. That is why you need to boil such things as beans before putting them into the slow cooker, as otherwise they never reach that temperature and can give you belly ache.
Nov 06, 2014 | Crock Pots & Slow Cookers
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    Can you boil in a slow cooker?
    Generally, with enough heat and good insulation, water will boil. Boiling is caused by non-uniform heating - some spots are hotter.
    My wife's slow cooker boils even on the low setting -slowly, but it boils.
    Our rice cooker never used to boil until I burned tomato rice in it (OOPs). Don't make tomato rice in a rice cooker.
    Mar 21, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
    Whats the differences with the low high and auto settings on a slow cooker which setting is considered best for cooking stews
    The difference is the time and how warm it cooks. Low cooks a slow, lower heat - cooks 6-8 hours. And High is a faster cook at 4-6 hours. I tend to use low for stews and chilis.
    Feb 11, 2010 | Crock Pots & Slow Cookers
    Ronson slow cooker don't know which is high or low
    on setting 1 (low),the slow cooker can operate all day and night if required
    when set to 2 (high) it is very much like a covered pot on the stove.food will cook in half the required time
    AUTO the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature,then switches to 1(low) and maintains a constant slow cooking temperature.Auto is ideal for someone who is leaving the house for the day 8-9 hours please feel free to share this information.If you have any more ? please fell free to contact me.
    bianca
    Jun 12, 2009 | Crock Pots & Slow Cookers
    Lost Manual - not sure which is high or low
    Hi. I'm a Ronson Service Centre.
    I grabbled this blurb from a Ronson Slow Cooker Manual. Not the same model, but it has the same settings:
    On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
    When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
    When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
    “Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
    Mar 15, 2009 | Crock Pots & Slow Cookers
    Slow cooker not hot
    If you only have High and Low on the slow cooker this will be normal until it reaches correct temp, the trick is Do not remove the lid once you have started the process, you lose 20 minutes cooking time every time you lift the lid during cooking, if you have timed ex,4,6,or8 hours just set to required cooking time and leave until done. hope this helps clarabella
    May 18, 2008 | Crock Pots & Slow Cookers
    Crock Pots & Slow Cookers Logo
    164 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
