Question about Microwave Ovens
My turntable has stopped going round? - Microwave Ovens
  • 17,115 Answers
Replace the motor
Posted on Apr 18, 2015
My oven's turntable has stopped going round?
take it to a repair shop as the rubber band under the unit has broken
Apr 18, 2015 | Microwave Ovens
Turntable has stopped going round
Excuse me for stating the obvious but did you check your control panel to see if there is a setting for the turntable? You may have accidentally turned it off.
Nov 13, 2014 | Microwave Ovens
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Microwave wont work
Call the manufacturer about resetting the electronics. If not possible the board needs to be replaced if the price is right.
check here Search Over 2 1 Million Appliance Parts
Sep 08, 2017 | Sharp Microwave Ovens
I have a GE Spacesaver PVM1870 microwave - the turntable has suddenly stopped turning. I've tried the "Turntable On/Off" button, but it did not help. What else can I try?
Perhaps the turntable motor has failed. Replace it as soon as possible as if you don't the food will not cook properly.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 03, 2011 | General Electric PVM1870SMSS Microwave...
GE microwave oven squeals as carousel is rotating. Noise stops in a minute or so but begins anew when the unit is used again.
If it is the wheel on the turntable that squeels, wash the turntable in strong solution of washing up liquid and water.
If it does it without a turntable fitted, change the turntable motor.
Hope this helps.
Jan 01, 2011 | General Electric Microwave Oven
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
Describe your Whirlpool JKP90B0M1BB Micro/Wall Oven combo/ doesn'
Sounds like the turntable motor is burned out or you may need a new coupler which is a plastic piece that sits on the motor shaft under the round glass tray. There is no button to make this work, it should rotate automatically when you select your time.
Jan 24, 2010 | Microwave Ovens
Microwave enamel wearing away
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Enamel should work, but appliance paint is better.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
