Question about Indesit 24 in. DI67 Free-standing Dishwasher
DI 67 Diswasher trips RCD fusebox
My DI 67 Dishwasher ever now and then trips the RCD mains circuit. Does anyone know why? I only use the machine once a day and it is on normal settings, not the intensive settings. I've also checked that nothing is blocking the washing or the pipes at the back. Looks like a heating problem. But not sure. Have to wait a few hours before trying and even then it may still trip the RCD circuit. Any ideas what maybe wrong?
  • 236 Answers
Re: DI 67 Diswasher trips RCD fusebox
Either the element is faulty or poss the electrical filter.
Posted on Feb 16, 2008
0 characters
3 Points
Dishwasher is tripping RCD, can it be repaired?
not necessary-- yet-- to buy a new unit
tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element
what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd
the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator
testing before buying may save heaps of cash
May 19, 2015 | Stoves Dishwashers
Hotpoint Aquarius SDW60 is tripping the mains power
is the circuit protected by an rcd/rcbo or a standard mcb as this may be a neutral to earth fault/insulation breaking down...try and get the machine portable appliance tested
Sep 05, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 Flashing lights 3 and 5
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Oct 21, 2008 | Dishwashers
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
Mar 25, 2008 | Hoover 24 in. HD83M Free-standing...
Problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Jan 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Washing machine
Sounds like you may have a corrosion issue or water ingress, causing a short. Could be a corroded heater, water in the main control board, water in the pump motor - the list is endless. Most washers tend to run the pump to ensure drum is drained before starting the cycle, so it would be probable that the problem is in the pump area.
You don't say if the main switch is an RCD or an ELB. I presume it's an RCD.
Oct 07, 2007 | Beko 24 in. D3421F Free-standing...
Dishwasher tripping fuse box
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Sep 14, 2006 | Hoover 24 in. HD96M Free-standing...
Tripping out RCD
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Aug 25, 2006 | Indesit 24 in. D63 Free-standing...
Indesit 24 in. DI67 Free-standing Dishwasher Logo
545 people viewed this question
Top Indesit Dishwashers Experts
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
