Question about Lorus Watches
How do i wind it. my wife bought it for me a month ago and the it loses time and the date keeps screwing up
4 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: luminox 3001 watch not keeping time
Because of the way they work, it's quite hard for quartz movements to run consistently slow - so if you find one getting behind, it's usually a sign that it's stopping intermittently. It would do no harm to check that the crown is properly pushed in after you've reset it, but my guess is that the watch will benefit from a new battery. A.
Posted on Apr 08, 2007
disap1
  • 98 Answers
SOURCE: My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Posted on Jan 10, 2010
hamletsgh207
  • 5 Answers
SOURCE: I have a navitimer world
Without seeing the inside works (movement) of your new (to you) watch and its parts, it's impossible to tell exactly what is going on, but no need to worry, as that's what competent watchmakers are for. Probably just needs a new spring, which wear over time due to many factors, including temperature, shock and corrosion. Basically, when you wind up any mechanical watch (whether automatic or hand-wound, regardless of age), you're tightening the spring which in turn is what powers up the watch (powering up the gears as it returns to its original position--i.e., unwinds, accuracy dependent thus on the spring among other factors). Sounds to me like it just needs a routine service, mechanical watches being no different than are automobiles, which require regular service as well. In the case of a watch, this will entail a cleaning, fresh oil and regulation, with old springs often simply swapped out for a new ones at that time by a watchmaker; routine services are a standard procedure which can be performed by any competent independent watchmaker, and don't cost a lot either. Most watch manufacturers recommend such service be carried out every 5 years or so, and while some can go longer (especially if not worn daily, same as a car when it comes to oil changes/service intervals), it's important to remember to service your mechanical time pieces which, if you do, will provide you with decades of reliable time keeping. All the best.
Posted on Jul 31, 2012
Raymond Weil Jasmine losing date everytime I go to wear my watch which is really on special occasions i find that I have to wind the watch to get the date right would this be a simple battery issue?
the problem is some month's av 28 days and some month's av 31days, but on your watch the wheel that as the numbers on has 31 days so if there's a month with 28 days you'll need to change it manualy hope this helps you,,
Aug 01, 2013 | Raymond Weil Watches
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
I have a navitimer world which i bought second hand a couple of months ago, but it seems to be losing time, it loses a minute or 2 a day, and every few days i need to reset the time,i wear it all day and...
Sep 05, 2010 | Breitling Navitimer World 715 A24322 Watch
Day date changes midday 12:00 PM, not midnight 12:00 AM. How to change this?
Your watch thinks your noon is midnight.
Wind the hands forward 12 hours and the date change will be at midnight. You will have to re-set the date if it gains a day when doing this.
May 28, 2010 | Bulova Watch
I bought this watch citizen BL5334-04E year ago,
Mechanically operated date changes occur at 12 O'clock. If your watch thinks it is midnight when it is noon then it will change date.
The solution is to wind your watch on 12 hours.
Apr 17, 2010 | Citizen Eco Drive Perpetual Calendar...
Jan 10, 2010 | Rolex Watches
Losing time stop after couple of hours
If this is genuine, it is Kinetic and needs to be wound for the first time as wrist movement sometimes isn't enough. Undo the pin that sets the time from its  initial position and then start turning the pin clockwise to wind it. If the time or date changes, you have pulled it out too far, push it back in as far as it goes without screwing it back in place then start winding it.  You will need to wind it about 50 times.
Hope this helps
Apr 25, 2009 | Breitling A1336313 Bentley Gt Racing Watch
Tag heuer carrera automatic wv211a
Your watch is a automatic. All automatics need to wind-up before being worn at first , or if not worn all the time. Automatics will work with-out being wound ,but will not keep time. Wind your watch at least 50 turns (using the crown) or shake about 150 times , and then try it . Automatics need that back-up power to insure it's accuracy.
Jun 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Luminox 3001 watch not keeping time
Apr 08, 2007 | Luminox Navy Seal Dive 3001 Wrist Watch
Watches Logo
26 people viewed this question
Top Lorus Watches Experts
gautam jha
Level 1 Expert
ray gallant
Are you a Lorus Watch Expert? Answer questions, earn points and help others
