Question about Pioneer Audio Players & Recorders
I have a pioneer Vsx-455 Audio video RECEIVER
The sub woofer only has speaker terminals how do I hook up a amp to it
4 Suggested Answers
SOURCE: SPEAKER CONNECTION
problem with connection
Posted on May 08, 2008
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
AJIN G
  • 6694 Answers
SOURCE: pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Sub Woofer works but it won't when hooked up to the receiver
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
Jun 23, 2009 | Pioneer VSX-D409
SUB WOOFER
Connect it to the "subwoofer out" plugs on the back of the receiver, red is positive, and black is negative. If no "sub-out" then seperate amp with speaker level inputs and low-pass filter...
Good Luck
Jun 22, 2009 | Pioneer VSX-D608 Receiver
Pioneer receiver vsx-d510 sub not working
Jun 21, 2009 | Pioneer VSX-D510 Receiver
Sub won't work
if using a sub out cable to a powered sub,you have to go into the reciever menu and turn the sub out on
May 17, 2009 | Pioneer VSX-406 Receiver
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Apr 08, 2008 | Pioneer VSX-454 Receiver
SPEAKER CONNECTION
Jan 07, 2008 | Audio Players & Recorders
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
44 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
