SOURCE: best wiring and best sub boxes for my solo x 12"
I did not realise yall used these boomers over there. search the internet I bet you can find every thing yoy want threre. just searrch car stereo
SOURCE: wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
SOURCE: wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
SOURCE: best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
SOURCE: wiring h2 2ohm sub
ASSUMING YOU HAVE AN AMP FOR THIS SUB, CONNECT LEFT AND RIGHT JACKS, RED AND WHITE TO BACK OF STEREO RUN TO AMP AND THEN FOR A TWO CHANNEL AMP YOU JUST BRIDGE THE TERMINALS SO LEFT + ON CHANNEL ONE AND RIGHT - CHANNEL TWO
