Question about Craftsman Welding Tools
Craftsman 100ac infinant amp arc welder just stopped working ....the fan still runs. anybody know what's wrong with it????
    Top Expert:
  • Craftsman Master
  • 50,572 Answers
Probably over heated and blew the reset button
100 amp welders have a duty cycle ( time in actual welding use ) of less than 20%
that means for welding for five minutes you have to let it cool down for 20 minutes
the lower the amps the longer you can weld for
beware tat the total amperage of the welder does not mean that you can weld for a long time at that amperage
on the plate on the welder is the duty cycle and you have to be aware of it or the machine will shut down
Posted on Apr 18, 2015
luxur4
  • 92 Answers
SOURCE: craftsman welder
.04 tips with .04wire with .04 liner etc.........
.025 tips wire .025 wire with .024 liner etc.....
Posted on Jan 23, 2009
SOURCE: no arc for craftsman professional wire feed welder
either your not grounded on the vehicle very good or you lost the ground either in your gun or on your clamp
Posted on Apr 15, 2009
  • 70 Answers
SOURCE: i have a speedline 180 amp arc welder and it
Check for output voltage (ac or DC depending on model).No voltage,welder has a problem.
You must have a clean ground clamp attached to bare metal with some welders to make them work.
Posted on Sep 23, 2009
KrisJohn1
  • 7 Answers
SOURCE: Lincoln Weld Pak 100 arc welder troubleshooting
There can be a switch that makes the wire electrically "dead" so it can be fed through the liner. Also suitcase style welders have a sensor wire with a clamp that must be connected for the arc to be able to be struck.
Posted on Nov 24, 2009
luxur4
  • 92 Answers
SOURCE: solar welder 2175 wire keeps feeding wont stop
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Posted on Jan 26, 2010
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Fan runs but will not strike a arc
The fan should be running on 120v, or one leg of the 220v. Something could be wrong with the other leg of the 220, short, bad contact, etc.
Jan 02, 2014 | Hobart Stickmate Ac/dc Welder Lx235 230v,...
Fan runs but nothing else
check small wire on opposite end of Gun. May not be connected well
Nov 17, 2013 | Craftsman 20568N 85 Amp 120 Volt Gasless...
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Problems with welding with a Forney 180 amp. Arc Stick Welder
check your input power connections on the primary side of the welders transformer, then if its an infinite control welder check that control,otherwise if it's a plug- in selectable amperage check these connections,it sounds like the infinite control is getting dirty and not passing all the current it shows on the control, also double your O.C.V. on the secondary and see if its with-in welder specs
Nov 15, 2009 | Welding Tools
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
Welding Tools Logo
231 people viewed this question
Top Craftsman Welding Tools Experts
AZBen
AZBen
Gil Shultz
Are you a Craftsman Welding Tool Expert? Answer questions, earn points and help others
