I need a user guide for this Alba LCD32880HDF
SOURCE: alba lcd32880hdf tv
Ive got a albe Lcd32880HDF And the picture goes off 14 months old sound only?
Posted on Jan 22, 2011
SOURCE: i have an alba lcd32880hdf
you whant servise.dont try nothing
Posted on Apr 17, 2011
  • 375 Answers
SOURCE: 32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
Posted on May 07, 2011
caroldon
  • 17130 Answers
SOURCE: i turn my alba lcd32880hdf
This is a common fault as the set on ageing deteriorates in the connections. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Jul 22, 2011
electron-man
  • 136 Answers
SOURCE: hi does alba LCD32880HDF have
there are two things you may need to do.
1) does it have a "pc input" connector on the back of your hdtv?
simply connect a cable to the "pc input" on your tv and the other end to your computer or laptop.
2) is your tv wireless or ethernet ready?
look for wireless router setup in the tv manual setup guide (or check online for it). check your wireless router for items it the wireless connection table to see if your tv is listed in there. or if there is a ethernet port on the back of your tv then simply connect a cat6 cable to it. however, limit the length of cat6 cable from tv to router to about 25 feet or you may not get a signal on the cable, your router will indicate this when there is a connection you will see lights for the connection. oh one other thing you may have to do is disable any wireless WEP in order for your wireless hdtv to connect to your wireless network. this may be unsafe to do for protecting your personal and private data!!
and anybody living around you may tap into your wireless network and get free internet access from you or be able to see your personal data
Posted on Aug 22, 2011
Alba lcd32880hdf has lost colour when watching Tv but works when using games console
It is almost for sure a bad connection at you wires. To show in black and white means your red and green are reversed or bad. I am guessing you have this hooked up with component.
Jan 27, 2014 | Televison & Video
Tv switches off and then when plugged back in flashes red and then blue will not come back on for hours
That happened to my 60 inch mitsubishi, fortunately mine was under warranty. The tv simply needs to be updated by the tv repaiman
Dec 07, 2012 | Alba Televison & Video
I set a parental control password on my alba lcd32880hdf 2 years ago and can't remember what it is. Can I reset it?
When you said this: They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
Jan 01, 2012 | Alba XJR 1300 SP Televison & Video
Alba lcd32880hdf tv after a few seconds the pitcher gose off
Jan 07, 2011 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
