Question about Garden
Blows a fuse every time I engage the cutting deck
The mower will start up with no one in the seat
    Top Expert:
  • Garden Master
  • 46,643 Answers
It is not supposed to start unless some one is in the seat
now for your problem, if engaging the cutter deck blows a fuse then check the wiring for a wire that is cut or shorting out on a lever that moves when the cutter is engaged
Posted on Apr 18, 2015
  • James Wolf
    James Wolf Apr 18, 2015
    I know it's not suppose to start when no one is in the seat but it does?
    Sergeant:
  • Garden Expert
  • 187 Answers
"Fuse blows every time I start the blades." This is a problem involving power from the battery which finds a shortcut to ground.
For a machine specific diagnosis we need some or all of the following:
  • Make
  • Model
  • Year
  • Engine Model (Briggs engines, look above the starter on single cylinder models, opposite side on twin cylinder models)
  • Transmission Model (sticker on back of tranny axle)
  • Deck Size
  • Hours on meter (indicates wear patterns and problems that only occur with time.)
  • If you haven't already done so, add a short description of the events preceding the beginning of the problem.
For now, I will assume your engine starts and runs just fine. That eliminates most of the electrical system problems. I will further assume that you have an electric clutch.
With an electric clutch power (12 volts) flows:
  1. From the positive terminal on the battery to the fuse.
  2. From the fuse to the Key Switch.
  3. From the Key Switch, in the run position, to the PTO Switch.
  4. From the PTO Switch, when activated, to the PTO Clutch.
  5. After flowing through the clutch it goes to ground.
So, somewhere between the PTO Switch and the PTO Clutch the wire is grounding to the frame. This is not uncommon. Look around the clutch and see if you find any worn insulation. The other and worse possibility (meaning more expensive) is a shorted clutch.
If the engine starts and runs fine until you activate the PTO, this shows us the rest of the wiring, prior to the PTO, is fine. Your problem can only occur after the PTO Switch.
Starting with a fresh fuse, sit in the seat and turn the key, one click from off to run, you will hear a faint click. That faint click is the fuel shut off valve under the carburetor. It is turning on and off when you cycle the key from off to run. Do not confuse this click with the Clutch click.
Leave the Key in the Run position, cycle your PTO Switch on and off. You will hear a click. This click will be twice as loud as the fuel switch click. This louder click is the Clutch engaging. If you do not hear this click, the PTO switch may be bad or the Clutch may be bad. This is assuming your battery is good and fully charged and that your Key Switch is functioning correctly.
On the other hand, if you perform this test and do not hear a click AND it blows another fuse, you have just confirmed the bad wiring/bad clutch scenario.
PTO Clutch will Not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
  • It does not give the air gap.
Examine your wiring for exposed wire. If you do not find any, you can proceed to do an ohms test on your clutch. If the clutch passes this test re-examine your wiring for a short.
A short cut test would be to disconnect the clutch harness nearest to the clutch. With a fresh fuse, run the PTO switch test again. If it shorts and blows the fuse, your problem is with the wire, likely not the clutch. If the fuse does not blow, your problem is likely with the clutch.
On a final Note: On all John Deere 100 series and other machines, you can and should be able to start the mower without being in the seat.
  • First get in the seat and lock down the brake/clutch.
  • Run the fuel lever up to choke.
  • Make sure the PTO is off.
  • On a manual tranny put it in neutral.
  • Step off the machine and turn the key.
  • Waaalaa, it should and IT WILL crank, start, and run.
Fixing Electric Clutches
  • James Wolf
    James Wolf Apr 19, 2015
    Fantastic information
  • 1,169 Answers
For starting with one one the seat either one safety switches has failed or have been bypassed.
For the blowing fuse problem if it has electric PTO test it for shorted condition. Most usually PTO coils have a resistance of 1.75 ohms. anything under 1.5 ohms is a severe shorted PTO coil. If it is a manual engaged PTO then either you have a wiring shorting ground or someone have mis-wired the safety switches.
Engine shuts down when cutting deck engaged
This is probably due to a misadjusted or faulty safety switch on the rider's seat. There is a deadman switch there that will shut down the mower if the rider gets off the seat with the blades engaged.
Mar 06, 2015 | Garden
I have a Cub Cadet 2135 mower deck issue: Started OCCASIONALLY shutting off on turns and down slopes. Turned the switch off then on and it worked until another seemingly random time as above. Now, deck...
repair the seat first remove seat and reinforce metal use metal plate on top and washers on bottom or reverse make sure seat is secure so that u do not loose the ground contact on safety switch their is also a safety switch on shifter lever and brake pedal check them for rust and a tight contact
Nov 02, 2013 | Garden
MOWER IS BLOWING FUSE WHEN I TRY TO ENGAGE CUTTING DECK
first unplug the clutch under the mower and try it if fuse doesn't blow its the clutch if it blows again check the wiring for a short
Apr 03, 2012 | Garden
EXmark mower blows fuse when deck is engaged.
try checking the wires from the switch that engages the mower deck. if there is a wire grounding out sumplace when you kick it on it will keep popping the fuse no matter what. id say its a short.
Mar 16, 2012 | Craftsman Garden
Starts and runs good but after an hour of cutting when you turn off.. then you want to cut again it will start just fine but when you engage the blades the fuse blows it has a 20 amp fuse is this the right...
I normally see 30 amp fuses to the deck...but it depends on which mower you have. If you place a larger fuse and it does take a 20 amp..you may burn something up. I would check the blades, spindle towers and clean all the stuff on top and inside the deck to look for something catching on the blades. www.nnyparts.com
May 27, 2010 | Garden
Snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
303 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
