Question about Car Audio & Video
How do I set/adjust the clock on a Wharfedale S-991 Tuner?
The clock on a Wharfedale S-991 is set/adjusted by pressing a certain combination of buttons on the tuner. I have lost the manual and no longer know the correct button combination. Any help would be greatly appreciated!
4 Suggested Answers
  • 24 Answers
SOURCE: I HAVE A KENWOOD KDC 122 CD CAR STEREO.
For the manual for this unit head to this page
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf]
However im pretty sure you actually use the volume or tune/seek to change the numbers then when changed to what you woudl liek again simply hit the main button you used to get into the clock setting originally,
Hope this helps
Cheers
Steve
Posted on Apr 03, 2009
  • 11 Answers
SOURCE: setting the clock
Use MULTI-CONTROL to select click.Clock appears is the display.
Pushing MULTI-CONTROL left or right will select one segment of the clcock display: Hour - Minute
As you select segments of the clock display the segment selected will blink.
Pushing MULTI-CONTROL up will increase the selected hour or minute,down will decrease the hour or minute
Posted on May 08, 2009
kenw392
  • 2226 Answers
SOURCE: I have a pioneer DEH-21001B
try putting the radio in standby mode first.
Posted on Oct 11, 2010
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
How do i change the clock time on my Suzukisv650s 2007 model? I'm not sure what combination to push the sel and adj buttons? any help appreciated
press select and adjust buttons simultaneously until hour display blinks,adjust hour display by pushing adjust button,push the select button to highlight the minute display , use the adjust button set your minutes , press select button to resume clock mode
May 29, 2011 | 2006 Suzuki SV 650 S
How to set time on jvc kd-r210
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
Nov 11, 2010 | JVC AM FM CD DET FACE CAR STEREO
I don't know how to set the clock on the jensen jbr550 radio in my bus
To set the clock, turn the radio on in tuner
mode (or any other mode).
Press D. The time appears on the display.
Press and hold D until the time display
begins flashing.
While the display is flashing, press the Up
Tuning button to adjust hours and the
“A” (AM) or “P” (PM) indication. Press the
Down Tuning button to adjust
minutes.
After five seconds, the time will set and the
display will return to tuner or CD display.
Aug 18, 2010 | Jensen Car Audio & Video
I need to change the time on it.
You can try the following steps
Setting the clock
1 Press and hold SEL (select) for more
than 2 seconds.
“DEMO,” “CLOCK H,” “CLOCK M,” “DIMMER,”
or “AMP GAIN” appears on the display.
2 Set the hour.
1 Select “CLOCK H” (hour) if not shown on
the display.
2 Adjust the hour.
1 2
3 Set the minute.
1 Select “CLOCK M” (minute).
2 Adjust the minute.
1 2
4 Finish the setting.
display mode
• During power off:
Thanks for using Fixya
Proton
Jul 27, 2009 | JVC KD-G200 CD Player
Can't adjust month/date etc....
1)Press "SET" button for more than 3 seconds until digits of certain area blinks.
2)Press " ADJUST " button to increase digit reading value of year, month, hour, minutes...etc. of the blinking area ( Note: all adjustments are towards increasing increments only. Just cycle if accidentally past the required setting )
3)Press "SET" button once to jump from one area of adjustment to the next...example from calendar to month to hour to minutes to seconds....etc.
4)Press "mode" button to confirm all settings
5)Finished
Mar 10, 2009 | NexxTech Transparent LCD World Time Clock...
Setting the time on car stereo/cd player
Changing the general settings
(PSM)
You can change the items listed on the next page
by using the PSM (Preferred Setting Mode) control.
• The PSM items are grouped into five
categories—“Disp (display),” “Clock,” “Tuner,”
“Color,” and “Audio.”
Basic Procedure
than 2 seconds so that one of the PSM
items appears on the display.
(See page 23.)
The currently selected
category is shown on the
left side of the display.
2 Press 5 (up) or ∞ (down) repeatedly
until your desired PSM category
appears on the left side of the
display.
3 Select the PSM item you want to
adjust.
4 Adjust the PSM item selected.
5 Repeat steps 2 to 4 to adjust the other
PSM items if necessary.
6 Finish the setting.
To set clock—Clock Hr, Clock Min
You can set the clock using the PSM control.
1 Press and hold SEL (select) for more than 2
seconds so that one of the PSM items appears
on the display.
2 Press 5 or ∞ repeatedly until “Clock” is selected
as the PSM category (it is shown on the left side
of the display).
3 Press ¢ or 4 to select “Clock Hr
(hour).”
4 Turn the control dial to adjust the hour.
5 Press ¢ or 4 to select “Clock Min
(minute).”
6 Turn the control dial to adjust the minute.
Nov 04, 2008 | JVC KD-G720 CD Player
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
the hour, then press
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
Clock
Press POWER to Turn ON the unit.
Press CD/Door OPEN.
With the Doors Open, on the Inside Right is a "Clock Set" Button... Press it once.
With the Hour blinking, press the "CD-Tuner-Skip" Up or Down Buttons to set hour.
Press the "Clock Set" Button again to make the minute display blink.
Adjust the minutes the same way.
Once the hour and minutes are both set, be sure to press the "Clock Set" button
one more time. Now the Hour and Minute display should no longer be blinking and
you should be good to go. (I just figured it out for myself.) Hope this helped!
Jan 04, 2007 | Fisher SLIM-2000 CD Shelf System
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
