Question about Dryers
Hasn't been using quite often since 2006, but recently when tried , it won't start when powered on, how to check if sth was wrong ?
  • Dryers Master
  • 5,323 Answers
Hey GOD IS GOOD !!!!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
GOD IS GOOD !!!!
Posted on Apr 27, 2015
I recently bought a 2006 Buick Terraza CXL. The radio/CD player and speakers worked fine. I put a DVD in the overhead player to see if it worked and it worked with vehicle speakers. I bought a set of
check power wire make shure yellow is in right place this is for your lights if hooked in with orange it shouldnt be orange is a consistant power sorce red is for only when ignition is on blue is for amplifier all darker color speaker wires should be neg lighter pos make shure none r mis matched make shure you do not have you fade left to right wrong same with front to back
Jan 16, 2013 | 2006 Buick Terraza
Truck just won't start. Light and everything else has power. Won't crank at all. Anti Theft system was not set and hasn't been used in almost a year. Had this problem a year ago but it
What year?? What I have run into is the Anti Theft cable shorts out causing the intermittent starting issue. I would try removing the cable
Oct 01, 2012 | Cars & Trucks
2006 ford f150 won't start`
check main fuse under hood
Sep 01, 2012 | 2006 Ford F-150
My Iomega 1TB drive is not playing fair!
seems like your omega drive will need reformatting completely then you should be able to transfer file to it.
I had similar problem with thumb drive and solved it this way
Mar 04, 2017 | Iomega Select 1TB USB 20 Black External...
My honda vti 2000 model,a/t.engine crank but won't start.what may the possible cause...thanx
Honest, there are over 3,000 reasons that it could be, but one thing about engines hasn't changed. They need FUEL, AIR and SPARK. Check to see that it has all three (like pick a piston easy to get at (if you have the tools, I 'assume' too much quite often) and see if it is getting "fire", if so is there fuel pressure? ... (as for "air" just make sure nothing has taken up residence in the air intake filter or pipes ...lol).
Aug 08, 2011 | 1999 Honda Civic
Wii will not come on no lights, nothing like its not getting power. had a recent electric utility failure hasn't worked since could this have been the cause?
Hi, my name is Shaun. i will attempt to help you with your problem. The answer to your question is "quite possibly." The electronics inside game consoles are particularly sensitive. A power spike resulting from an electrical strike on a power line or the amperage surge from the inrush current when power is restored could easily fry the delicate circuits. My best recommendation would be to have a repairman check the power supply and see if it is still good, or see if your warranty covers those types of repairs, if you have one.
May 23, 2011 | Nintendo Wii Console
Dryers Logo
139 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
