Question about Honda Garden
What type of oil does ryobi honda 3100psi 2.5 pressure washer uses ?problem that Im having is machine starts ok but there is no pressure Do u think having no water pressure is cuz being low on oil ?
    Top Expert:
  • Honda Master
  • 45,661 Answers
Extremely unlikely
most problems can be attributed to a blocked nozzle that will not allow the pressure regulator to bring the pump to full pressure
The system works like so
the pump uses the tap pressure to generate high pressure ( make sure tap is on and no kinks in the hose)
the pressure generated is fed through the regulator to the nozzle via a hand control
When the control is activated the regulator shuts of the by pass system and full pressure is achieved to the nozzle
when the control is released the pressure regulator by passes the water back to the inlet side and so releases the pump under load
Now if the nozzle is blocked it becomes the control and there will be no pressure
If it is partially blocked the pressure still need no pressure to work so at partial blockage it will still by pass water back to the inlet
Posted on Apr 18, 2015
Testimonial: "Thank you...Very helpful"
Start OK but if after warm up I push the choke to run, the engine stops, I used 4 time before and idled OK
Push choke to run???then not use on a all ready warm engine you mean you push the GAS lever ? remember a choke can work as a throttle for the engine. it can have a double function if your electric start contact is damaged you can use it to stop the running engine also.
How long you are owner of the machine , read the manual about it !
If before it worked good on this kind of proceedings as described ? then if you mean you push the gaslever to run Try it to do it again without the airfilter. I THINK YOU HAVE An AIR problem by carburator if its so clean the airfilter if its not to old. or replace
You can use for short time the choke in most cases minimize use of the choke short not more then 2 times max you pull.or electric start.
AND very important control in any case allways for THE RIGHT OIL level !!
If the engine is warm(hot) do not use the choke forget it it has no use. control your spark plug electrode i think you will find the cause.
Oct 12, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
We have a Ryobi pressure washer. Used one time. I have no water pressure.
Could be a stock Pressure Washer Unloader Valve. You can find videos of how to remove and to clean it. It is not that difficult to do. Good luck.
Sep 10, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Won't Stay On
If it's brand new, the first thing I'd check is the oil level in the Honda motor. Most pressure washers are tested then the oil is drained out for shipment. Honda motors have an oil sensor in them that will shut the motor off if the oil level is low. When the motor is off, all the oil is in the bottom of the crankcase and the sensor 'thinks' all's OK. When you start it up and the oil is getting splashed around it will get low enough for the sensor to shut the motor down. Also make sure the gas is turned on at the carburator.
Sep 04, 2012 | Homelite Pressure Washer. Honda 2700 psi...
Where do you add the oil on a DeWalt 3100psi pressure washer?
Hi and welcome to FixYa, I am Kelly
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Dewalt DPD3100 Gas Pressure Washer
Honda Excell 2600 no pressure and water is leaking from the pump. i believe it's the unloader but can i fix it myself. i'm handy with tools and repairs but do no have the manual.
a manual will not tell you how to replace the unloader if you have the same unloader you will need a pressure gauge to adjust it at 2600 psi and your spike pressure should not exceed 3100psi and the leak at pump you need to check your oil make sure is not milky and if not you will need seals also
Aug 23, 2010 | Garden
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
I have a Honda 3500 pressure washer. The motor
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 07, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
208 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
