Question about Samsung Televison & Video
How to calibrate Samsung UN55HU7250 TV. Horrible motion blur especially during dark scenes.
mfspencer
  • 58 Answers
SOURCE: LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Posted on Apr 02, 2008
  • 98 Answers
SOURCE: motion problems
You need to contact cable company, first for this.
Because of tyhe picture quality is related cable box, cables ,connectors & etc.
Posted on Feb 12, 2009
  • 50 Answers
SOURCE: TV Screen Dims during dark Scenes
Most likely you have the opc feture on. go to the menu under picture setting first option should be to turn on or off the opc. turn it of and should solve the problem.
Posted on Mar 18, 2009
bluenadas
  • 203 Answers
SOURCE: sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
Posted on May 04, 2009
milkburp
  • 416 Answers
SOURCE: KDL-32ML130 Sony Bravio 32' LCD HDTV motion blur
Logic board? Are you referring to the Main PCB (BU board I think). This issue is caused by the Timing Control board (T-CON). It’s the board directly on the panel that connects by LVDS cable to the Main PCB. Not sure if it’s a part you can purchase separate from the LCD panel, but give it a whirl… you never know. I hope this was of some assistance.
Posted on Mar 25, 2010
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
What is the best setting for the Samsung Led TV UE40D7000, I'm getting blured or juddering in moving scenes.
I have a Samsung UN60J630xxx that had juddering in movie scenes.
Use the Menu to go to Picture - Picture Options - Motion Plus.
Set Motion Plus to Custom and Judder Reduction to 3.
This fixed the juddering.
Oct 28, 2011 | Samsung Televison & Video
The picture tends to get really dark during dark scenes. Can hardly see faces or details. Goes back to normal during brighter scenes.
the only thing you can do is adjust your brightness, contrast, sharpness controls. every station is different especially the sound is louder on some channels and lower on some.
Mar 05, 2010 | Hannspree (K206-10U1-005) Television
Red cirle in the center of my screen durning dark scenes
This sounds like the light engine has gone bad or has dust/dirt in the light tunnel or DMD assembly. The light engine would have to be removed to check for dirt. If the engine is bad it can cost over $800 just for the engine not including shop charge. Unit would need to be taken to a repair shop to find out what is actually causing the problem.
Sep 06, 2009 | Samsung DLP HL-P5663W 56" TV
Mar 18, 2009 | Sharp Televison & Video
Samsung DLP Dark Picture
try to reset the tv setting to its manufacturer settings and see if it fix the problem
Feb 01, 2009 | Samsung DLP HL-P5663W 56" TV
42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Nov 28, 2008 | Philips 42PFL3603D 42 in. LCD TV
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
Dark scenes are impossible to see
This is a fundamental limit of Ti DLP. The part can not reproduce low grey scale, so low light film is dominated by artifacts. It helps to sit farther away from the screen. The color shift is caused by a factory tollerance on the color wheel, but there is no user adjustment for it.
Sep 10, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Blotchy picture
I get this too with my Samsung. Are you watching HD content or standard (cable, satellite) tv? If it's the latter, that's why. The lack of quality really shows on analog signals. The shows that I Tivo look horrible a lot of times. Another thing is the connection to the television. If you are using standard RCA connectors, try switching to either component or HDMI.
Hope this helps.
Feb 01, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
