Question about Black & Decker CC600 Shredders
Black n& DEcker paper shredder CC600 will not turn on
Will not turn on
    Top Expert:
  • 6,702 Answers
Check if there is power from the outlet. Check the cabling. Then do a check on the shredder to see nothing is blocking the free movement of the "knives " then check if all sensors are engaged. Not closing the shredder 100% ant the not closed sensor will prevent the motor to run. See and here if the paper in sensor is in tact and clicking when putting in paper. Needless to say, you better unplug the shredder when you open it to check.
Posted on Apr 18, 2015
    Top Expert:
  • 1,144 Answers
"Shredder does not start or stops while shredding?
Wait 30 minutes for shredder to cool down before trying again."
Black Decker SKU CC600 Repair
Black and decker shredder will only go in reverse, when you try forward it makes a loud sounding noise and will not take the paper
Shredders require maintenance. They have moving parts that make lots of dust.
Check your user manual. Does it require oil or special oiled sheets? If so, you might be overdue for this maintenance. Also, check the frequency of how often you are supposed to oil/add oiled sheets to it.
If it won't accept paper in the forward position, then you might be out of luck with trying to run oiled sheets thought it. If it's still under warranty, see if they can repair it for you.
Mar 02, 2015 | Black and Decker USA Black & Decker -...
Stops shredding before finsh
Did you clean up the reservoir, under the shredder? Or did you put in to many papers in the same time?
Sometimes you can put a little oil on the paper, to keep the thing going on. Special shredder oil is available in the store you bought your shredder
Jun 16, 2014 | Black & Decker Office Equipment & Supplies
Some small bits of paper are stuck in blades
My advice is not to try to take it apart. Try putting a sheet folded in half where the paper is stuck (or an envelope) to see if you can clear it. Go FWD and REV repeatedly. If you can safely pick at the paper from the top or underneath, do so but shredder blades are sharp to BE CAREFUL.
Does t go in reverse?
Nov 11, 2013 | Black & Decker CC1000 Shredder
WON'T STOP SHREDDING WHEN ON AUTO
You will probably find some shredded paper is blocking the sensor in the middle of the paper feed slot
Feb 26, 2013 | Black & Decker BD10P Shredder
Shredder will not turn on
how can i fix my black and decker shreder cc1000? It wont power on and it is in good condition.
Jan 12, 2013 | Black & Decker CC1000 Shredder
Small strip of sticky paper stuck in shredder opening so the shredder runs continuously. How can I correct this?
Plain and simple you will have to get that paper out by any means necessary. Long tweezers, needle nose, knitting needle, vacuum....etc. Unplug while you are doing that.
Jan 05, 2013 | Black & Decker CC1000 Shredder
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
I purchased Shredder Model BD-S600 on 5/6/11. This was to replace another Black & Decker Shredder that I had for only a few months also. Today, when i attempted to turn shredder on to shred some...
If it's like my BD-S600 your motor is already burned out!! Same thing happened to me with this shredder after 3 months of minimal home use. I had to call them and pay $13 to send shredder back to them to have a new one sent to me, and I have already been on the phone with customer service due to problems with the new one after 5 minutes of use! Good luck to you; I know I will NEVER purchase a Black and Decker shredder again! My last shredder (a Brother) lasted 8 years with no problems and I really miss it!!
Jul 05, 2011 | Black & Decker Vacuums
Need owners manual for B&D paper shredder Model BD-10P. i have a jam
Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
Apr 07, 2011 | Black & Decker Garden
Black & Decker CC600 Shredders Logo
323 people viewed this question
Top Black & Decker Office Equipment & Supplies Experts
Tony
Ngoro
Ngoro
Jerry Kramer
Jerry Kramer
Are you a Black & Decker Office Equipment and Supply Expert? Answer questions, earn points and help others
