Question about Grundig FR200 AM/FM/SW/DAB Radio
I bought a Bush digtal/ AM/ FM radio ("retro transistor" style). DAB reception dropouts lasting several seconds each time have started occurring recently. AM/ FM is ok.
I often leave the digital radio on all day as a home security measure. Can prolonged use of the digital radio function normally cause it to "wear out"?
  • 3,961 Answers
Constant usage of DAB should not cause it any damage ever. The dropouts are very characteristic of a poor signal reaching the DAB tuner, as digital is either there, or not there, nothing in between.
Check the aerial connection if any, the rod antenna if any, and try moving the antenna (whatever it is) to a better location, usually higher up, away from thick walls, and away from speakers if any.
Posted on Apr 18, 2015
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
Radio keeps scanning through all stations
Dab reception has frozen on my panasonic radio FM is OK .how do I fix
Sep 18, 2013 | Dewalt DC011 AM/FM Radio
Lost Owners Manual Bush Radio/br10 dab
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution posting. Thank you for choosing FixYa to assist you with your request. You lost the Bush Radio BR10 DAB + FM Radio Owner's Manual, and you need help searching for another one? Just click on the link below to retrieve your owner's manual. It will be downloaded to a pdf file.
http://www.worlddab.org/device/manual/1049/BR10DAB.pdf
Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns or requests. We hope that you find what you're looking for. Please visit our website in the future. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Jun 02, 2011 | Audio Players & Recorders
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
Grundig FR200 AM/FM/SW/DAB Radio Logo
568 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
