Question about Alcatel OS6850-24X CHAS L3 GETH 1U 20 10/100/1000 (OS6850-24X-US)
Where is menu button on the d100 - Alcatel OS6850-24X CHAS L3 GETH 1U 20 10/100/1000 (OS6850-24X-US)
How do i reset d100 to factory specs
The D-90 and D-100 are similar so this may work for you. On my D-90, you go to the menu, then click on the little pencil Icon. The top line will read: Reset Custom settings." Click on this line then click "yes" to reset all custom settings back to default. You can also reset individual settings back to default by clicking on the line for the specific setting you want to reset.
In addition, on the top right side of the camera you will find a "+/-" button and an "AF" button. Both are marked by little green dots. Press these two buttons simultaneously for several seconds and it will reset most of the custom settings back to default.
Apr 16, 2014 | Nikon D100 Digital Camera
Can't access DVD setup menu
Without its original remote control, you can't access it all functions. Try to get one original one. Contact the authorized service center for Sony.
Jun 02, 2013 | Televison & Video
The pictures I take with my Nikon D100 come out really dark. It's dark when looking through the viewfinder as well. What do you think is causing this to happen?
First thing to check is the shutter control or maybe what speed your shutter is on. Check your settings and you'll probably find something is switched to the wrong setting. Try switching everything to Auto, including anything menu operated your manual should explain how to get to your on-screen menu. Try that and if no good, post back and we can take it from there.
With cameras getting more compact and buttons getting closer together and smaller it's very easy to knock a switch the wrong way without realising it.
Apr 14, 2010 | Nikon D100 Digital Camera
VIEWING PICTURES - nikon d100 digital slr
Try this...go into the menu and find "reset"...follow the on-screen instructions.
Dec 29, 2009 | Nikon D100 Digital Camera
D100 black image after photo is taken
Have you accidentally turned off "review"? You can also go to "reset" in the menu and try that.
Sep 17, 2009 | Nikon D100 Digital Camera
My D100 will not accept CF cards
You can always try the reset button. It is under the flap where the USB/Video out/ and power connector is. It is just above the power connector.
Oct 01, 2008 | Nikon D100 Digital Camera
D100 showing double images
I had the same issue and was directed to page 87 of owners manual. Chances are good that you have white balance bracketing on. This produces two images and can be turned off with the bracket(BKT) button and or CSM menu F11 WB Bracketing.
Aug 10, 2008 | Nikon D100 Digital Camera
Finalize
to finalize the disk for enabling discs to be  played on other devices. Connect this unit to the AC adaptor. Finalization cannot be executed using a battery. Rotate the mode dial to select the arrow. Press the MENU button, then select SETUP, FINALIZE, YES and press the joystick. Select whether or not to create a top menu, then press the joystick. When the confirmation message appears, select YES then press the joystick. hope this helps you. julie
May 19, 2008 | Panasonic VDR-D100 DVD Camcorder
Stuck shutter release button on my D100
Ouch...
The damage may require parts, but maybe not. If I were doing the work, I would charge in the $50-$60 range , plus parts if needed.
Nikon will likely quote you much higher $200+
You can use the repair service locater here on Fixya to find a repair shop in your area
Mar 24, 2008 | Nikon D100 Digital Camera
Nikon d100 error code r03
If you have a "r03" display, then you need to go into your CSM Menu, and scroll down to CSM #4, and turn LONG EXP. NR to "OFF". When you are in Noise Reduction Mode, your D100 buffer is literally cut in half.
Jan 01, 2008 | Nikon D100 Digital Camera
Alcatel OS6850-24X CHAS L3 GETH 1U 20 10/100/1000 (OS6850-24X-US) Logo
207 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
