Question about Nokia E71 Smartphone
Phone does not turn on with power button - Nokia E71 Smartphone
How to turn it on
Samsung Galaxy S3: How to turn it on:
On the right side near the top you will find the power button.. press this down with your right hand finger for a couple of seconds until you see something happening on the screen.. then let go. The phone will power on:
>> While power on the phone make sure you don't do this:
Cradle the phone in your hand, be careful not to press the volume key.. doing so while holding down the power key will affect what the phone does..
Also make sure that your hand or fingers don't rest on one of the bottom (capacitive) buttons (these are buttons activated by touch) near the home button.. it can also affect what your phone does while holding down the power button
I will demonstrate turning on the Samsung Galaxy S2 which is similar to the S3 in the video below:
personalized video tutorial 16.9 MB:
Jan 24, 2016 | Samsung Galaxy S3
Power button on my phone won't work
i think your power button is broken
Mar 22, 2014 | Pantech Cell Phones
I put my U5i to charge and when I woke up in the morning it was shut down and I can't turn it on...In two words the phone died.
Did you drop the phone in water recently? Did you get it wet in the rain? Apart from the likely possibility that the phone is actually damaged/battery damaged, this happens if the power button gets damaged. When you put the phone to charge, in the middle of the night the power button "acted" as if it was pressed and held and the phone turned off. Now when you press the power button, nothing happens because the power button is damaged.
Take it to a repair shop and check the power button for damage. It is replaceable and should not cost a lot.
Does your phone have a removable battery? If yes then you might be in luck. If not, then just take the phone to repair shop and get the power button checked and repaired.
If battery is removable I know that it is possible to turn on the phone this way:
1) Plug in the charger to the phone
2) Remove the battery and insert it immediately. Do this multiple times and the phone should turn on without having to press the power button.
Hope that works.
Sep 27, 2013 | Sony Ericsson Vivaz U5i ruby Red Unlocked,...
Any tricks to turn on my LG840G with broken power button
Plug in phone, and remove charger as soon as, or right before phone turns on, then constantly press buttons on bottom of the screen.
Jul 02, 2013 | Straight Talk LG840G Cell Phone
How to reset a Nokia Express Music Phone?
If the phone is not showing any activity, proceed with hard formatting , turn off your phone, hold the following buttons while pressing the power button--default code is 12345.
For HARD Reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons ( for Nokia 5800XM - use the following buttons to do a hard reset, GREEN/RED/CAMERA keys pressed all at once on power up
Dec 20, 2011 | Nokia Cell Phones
How to turn LG phone on?
Usually you push the power button. Which is the red one
Mar 19, 2011 | Cell Phones
My cell phone turned off and it won't turn back on. How do I get it to turn back on? I've tried the power button and already tried the volume, home button and power button at the same time trick.
Plug the phone into the charger. With or without the battery the phone should turn on when you hold the power button for more then 2 seconds. If the phone does not turn on then you should check with the manufacturer about getting a replacement under the Manufacturer's Warranty.
Feb 28, 2011 | LG Ally Cell Phone
Need to turn phone on but the power button is broke. It charges and turns on but just the charging screen
you need to replace the power button so that you can power your phone well again.
But there is another way by which you can power the phone without the power switch. This will involve you opening the phone cover so that you can gain access to the power button area on the phone board/panel.
Get a phone screw driver, open the phone, insert the battery into the phone, get a tiny wire and bridge the power switch panel and the phone will power on.
Try this, and it will work. I am very sure about this.
Take care.
Mar 18, 2010 | Samsung Blast Cellular Phone
Motorola Q power button
This is a difficult question to answer. First, make sure you did not accidentally drop any liquids on your keypad. Second, try removing the battery and replacing it. Thirds, try a Master Reset (Start, System Tools, Master Reset) BUT REMEMBER THAT A MASTER RESET WILL CAUSE YOU TO LOSE ALL PERSONAL DATA. After that I am afraid you may have to turn your phone in on an insurance claim. Good luck.
May 29, 2008 | Motorola Mobility Moto Q
The phone will not turn on
May I know what is your phone model?
May 21, 2008 | Nokia N95 Cellular Phone
Nokia E71 Smartphone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
