Question about Bogen Manfrotto Tripod Head- 3030
Need to replace the spring , but cannot figure out how to make it work.
I have all new parts, but cannot get the spring to keep tension. How to place spring in thumb release?
How to disassemble
The entire tension assembly will come out intact. There should be a screw (usually about 8-9 oclock) that holds the unit in place. Loosen it and pull assembly out. There will be another screw that holds the big round part (that was back in the machine before removing). Loosen and slide off, then remove and replace spring. Make sure when you install that its not in too far that it keeps your tension discs open all the time or you won't be able to adjust the tensions.
Aug 06, 2014 | Consew CN2053R1 Sewing Machine
How do you replace the chain tensioner on a Razor E300
Theres an 8mm nut holding it onto the pin that goes thru the frame.
Take that nut off and remove the tensioner. Put some grease on the new pin where the tensioner goes. Put the end of the new spring into the hole in the frame next to the pin hole. Hold the tensioner in place and put the pin thru and the nut back on. You should be able to get the chain back on the sprocket without loosening the axle nuts. Hope this helps.
Aug 03, 2014 | Razor E300 Scooter
Is it possible to tighten a loose belt on my cub cadet RZT-54 ZERO TURN RIDER.model number 17AFCACK009
HI,
I assume you are reffering to the mower deck pulley...however, the belt that drives the two hydraulic motors work the same way as deck pulley system.
First, there is no manual adjustment on the pulley system. Rather there is a spring loaded pivot arm to which an idle pulley is fastened to. The spring pulls the pivot arm in such a way the it forces the idle pulley to keep the belt tight at all times. The same setup is used on the ground drive belt.
Sometimes these springs become disconnected or break so that no tension is placed on the belt to keep it tight.
Check the tensioner spring to ensure that it is connected properly and applying tension to the belt. Otherwise, you may have the incorrect belt installed, the belt is routed incorrectly or the belt may be stretched out and need replacing.
Here is a diagram to clarify, the spring is the dark black item;
Here is a link to a large diagram that is easier to read;
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
Jul 14, 2014 | Garden
I need instructions on replacing the thread take up spring Juki DDL 8700
contact a juki dealer to see if they can give instructions
Jan 31, 2012 | Juki DDL-8700
My honda 5hp engine electronic ignition rewind rope broke and I am having trouble installing the new rope and getting it to work
might seem like a easy fix but they are very awkward to try and fit you need to take the case of were the rope goes into but when un doing the case and removing you must do it very slowly as the coil spring is under exstreme pressure and if the coil spring pops out of the casing then it is a nightmare trying to put back together but if you manage to get it of in one shot you will see how the rope is tied and were it sits in the groove so you need to remove the old knot from the rope and refit your new one and try and keep the tension on the coil spring a little hard to exsplain but give it your best shot and wear some glasses as the coil spring can go all over the place as it is wound up several times to create the tension for the pulling action and to retract back if it dont work out for you just keep all the parts and take it to your local tool repairer and they should fix it for around 15 to 20 dollars
Jul 06, 2011 | Garden
I'm in trouble deep-I was trying to fix an old
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
How do you make the tensioner release to tighten the timing belt?
The belt tensioner keeps the belt tight inside each accessory pulley while the engine is running. The tensioner is made up of a spring-loaded arm. If the spring inside of the tensioner becomes loose then it will not be able to hold the belt properly.And belt will also get loose. The belt tensioner is on the engine underneath the alternator. Its fitted by bolt.To loose the belt you will need drive socket and breaker bar .Turn the breaker bar counterclockwise to release tension from the belt.Remove the mounting bolt at the top center of the tensioner arm.The tensioner arm is loose and will easily come out.If you in-case are to replace the tensioner then place the new tensioner in same place and tighten the bolt which you removed.Before removing or moving the belt check the position of the belt passing from each pulley.so that when you fit the parts there is no problem in fitting the parts.
After its done.Start the engine and see that belt and tensioner runs freely and belt moving from each pulley smoothly.
------------- This will help.Thanks.Helpmech.
Dec 06, 2010 | Pontiac Grand Am Cars & Trucks
Apparently the springs on my door are either not connected or they need to be adjusted. If I were to open the door and not hold it with my hands, it would immedaitely fall wide open. No tension exists on...
I had the same problem on my Dishwasher . There should be 2 screws underneath the top front part of the dishwasher. They hold the unit in place. Easy to get to. Open the door and look up. Pull out the 2 screws that are screwed into the underneath of the front cabinet.
This should allow you to pull (slide) out the unit just enough to see the springs ( aprox 1 ft ) on both sides on the bottom of unit. Inspect the springs. Mine had broke on one side where it clips into the holder.
I just inserted the spring in the proper tension hole to match the other side . I spun it around 1 turn as to hold it in place and then connected the top of spring it its proper place. This gave equal tension on both springs and the door works fine now.
Eventually I will buy a new spring and replace it but at least it works fine for now.
If even one spring has been disconnected the door will fall with out any tension what so ever. I'm guessing maybe just one spring has either come out or broke where it clips into the hole.
Aug 30, 2010 | Frigidaire FDB520RHS Full Console...
When it spin a burning rubber smell is very strong and the wash is not ready for the dryer because it is still very wet. My washer is Maytag model LA810 series 01 serial# 013122 LR Ihave changed the belt...
New washer? probably not, but you very well may need a new tensioner pully spring.
Either the new belt is the wrong size, or it is installed improperly, or the tensioner is not providing enough tension to keep the belt tight. Make sure the moving parts are oiled. Sticking parts can also prevent the tensioner from pulling properly.
Oct 03, 2009 | Washing Machines
Washer will not start
"Fdl" is definitely a door latch error. This will cause the washer not to start. You will need to replace the latch to keep from getting errors and intermittent problems. It will only get worse until it fails altogether. To replace, just follow these steps: 1. Unplug the washer. 2. Feel around the rubber door boot along the front edge. At the bottom, behind the rubber you will find a tension spring. Pull the tension spring out and remove the wire retaining hoop. 3. Remove the door boot from around the door opening and push inside the washer so you can access the door latch behind the front panel. 4. Remove the three screws on the front of the washer that hold the latch in place. 5. Carefully remove the wire connecting plugs to the door latch and remove latch assembly from plastic retainer holding it in place. 6. Replace the door latch in the reverse order of the steps given. 7. Reinstall rubber door boot around the door opening making sure you seat the rubber all the way around the groove. 8. Now comes the hard part - putting the retaining spring back in place. Position the tension spring at the six o'clock position and start inserting the hoop from the top first, working your way around to the 4 and 8 o'clock positions. The assistance of another person would be great right about now. Hold the hoop in place at the 4 and 8 o'clock positions, making sure you keep enough tension on the hoop to keep it seated in the groove. 9. Stretch the tension spring in order to snap the remainder of the hoop back into place. I know this may seem like a lot, but it is a fairly simple repair. I hope this helps you.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Bogen Manfrotto Tripod Head- 3030 Logo
184 people viewed this question
Top Bogen Photography Experts
Coss
Mai Lor
Tony Parsons
Tony Parsons
Are you a Bogen Photography Expert? Answer questions, earn points and help others
