Question about West Chester University 3100/XL - Size X-Large by West Chester
Hoe to tighten the belt - West Chester University 3100/XL - Size X-Large by West Chester
    Novelist:
  • 165 Answers
Insert the pry bar above the alternator pulley. Apply gentle pressure upwards so that it adds tension to the drive belt. Once the drive belt is moved into its desired tension, tighten the adjustment bolt to lock the belt in place. Then, torque the adjustment bolt to the manufacturer's specifications.
Posted on Mar 30, 2017
Can I have a diagram on hoe to replace the drive belt for a Poulan Pro 42inch 18hp?
Here is link to parts manual. Page 14 shows belt and shape to go around belts. I have found it easiest to remove deck and clean drive shafts for blades and idlers etc. that way new belt will last longer.
Feb 27, 2017 | Poulan Garden
Hoe to tighten lower looper thread on a white speedylock 299
That would be the tensioner for the lower looper. On most machines, moving the tensioner to a higher number will tighten the thread.
Jun 02, 2015 | Sewing Machines
John deere belt routing
hoe's dont replace belts... they take them off !!!
Aug 21, 2014 | John Deere Garden
Roto-hoe model 800 chipper shredder manual with parts list
http://mytractor5.blogspot.com/2014/04/roto-hoe-500-800-2000-series-chipper.html
May 02, 2014 | Refrigerators
Torquing head bolts
Ist thing, you should replace the bolts with new ones. Tighten main bolts 1 thru 10 to 25 ft pounds. Next, tighten bolts 11 thru 14 to 37 ft pounds.
Apr 01, 2014 | 2002 Saturn L-Series
Moen loose faucet handle model ca87011srs. Cant figure out how to tighten handle.
The logo spoken of is a little piece of plastic stuck in the hole that the setscrew is hiding in. Pop it out and check the set screw.
Nov 30, 2013 | Plumbing
Where do i start how to install timing belt on a 2000 2.4 hyundai sonata
First remove all. Power-steering pump 3 bolts on cylinder head. Loosen the alternator. remove the two belts. Underneath the car. remove black wheel arch plastic cover (6 or 7screws) Loosen the air con pump tension-er pully. Remove belt. put a trolley jack under engine as the mounting needs to be removed and lift the engine slightly. Remove the engine mounting bolts next to the black cam belt cover and remove the mounting. Loosen the Main crank shaft pulley. Normally very tight put a power bar and socket on. engine turns forward so let the bar rest on X member and turn the key only so that the engine turns. do not start. Remove cam belt covers (comes in to parts - top and bottom) then loosen the tension pulley which is on the left. 1 x bolt in middle. remove cam belt. now the tricky part. Replace the bottom crack pulley. turn so that the marks are lining up. the cam pulley has got a small hole in turn the hole upward to the top of engine. there is a small dot on the cylinder head which can be seen through the hoe. line up. replace idle pulley on the right. replace tension pulley on the left. put new belt on and now to tension the belt. take a number 5 or 6 allen key and turn the tension er clock wise until its like a watch at 10 min to the hour. tighten the bolt. test belt with fingers. if belt to loose you will feel the belt move easily. belt must not be to hard when pressed. try to turn the belt with fingers half a turn if going passed the halfway mark tighten some more. Use power bar and ensure engine turns properly meaning two or three full turns with hands without it getting stuck. otherwise the valve and piston is toughing. if so do crank turn of 180 degrease. free turn again. should be right. replace all that was taken off. start car. if belt tension is to tight you will hear a signing sound.
Aug 04, 2010 | 2001 Hyundai Sonata
Belt is slipping
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Mar 29, 2010 | RTO Image 15.0R Treadmill Walking Belt
Frist 2 mins makes a bad nosie then when car gets going it stops think it is the fan belt on my vauxhall vectra hoe do i tighten my fan belt
replace belts they are glazed from slipping and better to replace them now then damage your cooling system or boil over and trash your motor
Mar 27, 2010 | 2001 Volkswagen Golf
Need to inspect tumbler, belt etc. Hoe do I get
Unplug the dryer.
Open the door.
Remove the 4 visible screws.
Raise the hinge side of the door and remove the door,
The front panel will pull out.
Remove 2 screws on the top right and left of the cabinet just under the top panel.
Raise the top.
You will also have to remove the front drum support. 2 screws right and 2 screws left.
Mar 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
West Chester University 3100/XL - Size X-Large by West Chester Logo
1,173 people viewed this question
Top West Chester University Work Safety Experts
Bobby Lewis
Bobby Lewis
Johan Erasmus
Johan Erasmus
Are you a West Chester University Work Safety Expert? Answer questions, earn points and help others
